Birds I think I just found your Christmas pressie.
http://hellogiggles.com/feminist-coloring-book/2/#read
Why have I never met an attractive feminist?
Are they ugly because they are feminists or are they feminists because they are ugly? Chicken or the egg...
JUST had a customer turn up.
the flamin mongrel was so hipster i was expecting hamish to fire a scud missile on the flamin mongrel.
patchy beard- check
thick rimmed glasses- check
gay haircut- check
short shorts from 1943- check
gay shirt- check
crocs- check
just when i thought this flamin mongrel couldnt get any queerer.
he rolls a ciggarette and lights it up using matches, after failing a couple of times.
doesnt use lighters because theyre too mainstream
I'll just take cash.
Vietnam seems too much like Bali..?
+1 Vietnam, its not a party-place like Bali.
I was celebrating NYE in Hanoi, Police came into club (disrespected my family) & shut it down at 11pm. No place was open past 11pm on NYE.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
