It's always funny how brave politicians become with their opinions post-parliament days
It's the life cycle of politicts.
When people are young and idealistic they often align with left wing values because they deserve everything for free and have mostly survived on someone elses income. Also because governments are evil and corporations are corporationy.
Then they get older and start working. They have more life experience and see that idealistic left wing values don't help the economy much, nor thier own hip pocket and in turn become more and more conservative.
Then once they have been successful for many years and are confident in their retirement nestegg the pressure is removed and they can become idealistic again.
Only got one pair from years ago, not a big fan of the majority of them... Why's that?
Just grabbed my first pair... usually go for 90's. White on white with black soles from the iconic $128 shipped. They have most sizes left.
Way more comfy and look better IMHO
VEEEERY hard to find in 14 though.
I don't mind a few of the 1 coulorways, just never bought a pair..apart from the ones I got way back when, they're pretty thrashed these days though...
Running out of 90's to buy that I like, so maybe I'll add some 1's one day
Oh, so rather than pay less tax you just earned more...
Hold on while I search the bank for a f**k to give
Edit: sorry man, we're tapped... our last f**ks for the financial year are all allocated to the shareholders
Haha unfortunately with today's interest rates I'm positive geared.
Thanks Ham.
Also, don't blame me... you chose to sign up at that rate. If you wanna pay enough to be negatively geared there are plenty of products available ;)
  • Like 1
Birds only charges 10 points vig in the first week
After that 15 and after that I introduce you to dezz who works for 20
Capisce?
You can thank ya mother for that
Now go home and get ya f**kin shine box
  • Like 2
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
