They need to recoup hecs way faster and cap it at like one degree there after fund it ya self fkn art students.
Waiting to hear about my tax am
Anticipating significant return .. Although paid a ridiculous amount of tax
That doesn't really help the situation for people who can't find jobs...will make it worse if they gotta pay more. Need to pull hecs funding out of industries with an oversupply of candidates, like engineering; a loan scheme should be used to draw prospects towards jobs in need of more candidates and away from the overpopulated areas that result in people being jobless and on welfare with no quick way of paying back the debt.
  • Like 1
Courtesy of my income tax receipt:
Look at all that welfare...families is getting damn close to pensions...like ffs, if you can't properly afford kids don't have!
  • Like 1
Except you can't predict where the industry or demand will be in 3 to 4 years.
Engineers who started their degrees four years ago were in the boom times, when they've finished the boom was over.
I started my engineering degree in hopes of working for Toyota/ford/Holden. Then recession happened in my last year & they all shut down.
  • Like 2
So birds, plsh explain again how Tomich is not a flog and it's all Tennis Australia's fault
Tomic arrested after drunken party in luxury Miami penthouse http://ab.co/1GoVb4P #abcnews
pfffft who hasn't been arrested after a drunken party in a luxury penthouse these days
exactlly.
for me it was Comp Sci and the dot com boom.
I was lucky enough to get a job about 3 months b4 it kicked in, after leaving uni 12 months early.
those that started with me and got their degree, bad luck.
That's a reasonable point but people study endlessly because the can and it's free and get bs degrees and have no thoughts of paying hecs back. There should be at minimum and incentive to pay it back faster ie 10% discount
the numbers of permanent students is tiny, those there for like 10 years are usually getting Phd's and such and will earn it back in the log run.
yes there a few that don't want to work but it's easier to be on the dole with much less work.
as for the discount if it still like when I was paying it back if you make lump sum payments on top of the stuff coming out of your salary then yes there is a discount. used my first couple bonus at work to kill mine off.
oh and it hasn't bee called hecs for years, it HELP now and your all showing your age.
A good point.
You may not be able to predict demand (to a degree you can; what a pun!), but you can certainly count the number of enrolments and be aware of big trends in favoured courses or career paths. I'm not sure how the qualification process goes to decide which course is hecs eligible, but surely a government department has a say in that - yet it's the universities spitting out places and degrees like nobody's business.
It's pretty dumb to let people start a degree during a boom when it's not expected to last - that's a recipe for debt that won't be repaid anytime quickly and another person on centrelink.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
