$500 on train ticket. If you plan on hanging around Tokyo you'll need at least a few days in the city.
Bullet trains are quick but it's still 6+ hours from Tokyo to the other major cities, so keep that in mind with how much luggage you're taking and how long you want to stay at places.
interesting.
would want to do the usual car shit.
visit nismo, ebisu etc, but also not doing things that turns me into a short fat ball of extreme rage would be cool. im hell bent on going to monkey island (dont know what its actually called)
Thought this was captain will for a moment
http://www.sau.com.au/forums/topic/458336-fs-r34-gtr-v-spec/#entry7569908
Then remembered his was midnight purple and that he's probably in jail or working for TMZ
replica parts on a bayside blue 34R? geddouttahere
also: whats the point of listing spares if they will be an additional cost ontop of the car?
Surely he's had several color changes over the years
In the hood they identify niggas by their cars so I switch up whips to stay off the radar
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
