Where'd you get those from?
I'd love to piss off the neighbours with loud music while I'm away on holidays
I have a remote control power board but don't use it to full advantage
Belkin wemo switch. Dicksmith had an online sale.
Can also write rules with IFTTT
On another note bought some wifi-controlled electrical outlets.
Can switch on the heating before I arrive home.
#Homeowner 2.0
Got mine auto setup to turn on an hour before I get up, then turn off as I leave, its mad.
Dem gas bills doe, suppose electric ones are better bang for buck?
Edited by UNR33L
  • Like 1
I switched from Gas to Elec heating this winter... will update when bill arrives
so far gas bill has arrived and dropped from $46 to $29 per fortnight (bill smoothing)
if the Elec doesn't increase by more than $17 per fortnight then I declare elec the winner
Got a $100 rebate on my last waterbill.
No idea why...
Googled it and there's a whole bunch of rebates you can get for energy efficient washing machines etc. Can claim up until September for rebates effective until June 30th.
How you supposed to know about this?
No idea why...
will look into this....
i'm shitty at my water company so I would love to claim a rebate and I have a new washing machine and dishwasher
Any of these:
Product information Type of water saving product you are claiming (refer to brochure or visit www.water.vic.gov.au for further information) Basket of Goods – $30 Tank to Toilet Connection – $500 Water Audit – $50 Permanent Greywater System – $500 Dual Flush Toilet – $100 Rainwater Tank Rebate – $850 or $1300 or $1500 Pool Cover with roller/wheel – $200 Hot Water Recirculator – $150 Showerhead – $10 or $20 Washing Machine – $150 (5 star water & 4 star energy rated)
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
