what car next?
anyone know if i can get refund on my registration after stolen/write off? (remaining months) just paid for it 2 months ago >_<
Yeh insurance will cancel it and Vic roads are required to send the refund to you unless vehicle is under finance
140 is plenty on a 2fiddy...if you're gonna replace em get Michelin Power Pure...fking awesome tyres! Still want an old school Duc?
lol the ducs i want aren't old school! dunno the 749 is still expensive and don't think i'll be getting a Dez spec tax return anytime soon.
like the cbr600 but i'm 94% set on the daytona 675 since it's priced similar and looks way better
I'll see if I can afford to buy the coffin at the same time as the bike
i'm sure a 600/750 is just as dangerous lol
Is there some rule that electric cars can't look good?
tesla doesn't look too bad...
what car next?
yes
got a rego refund when i wrote off my car
Daytona is a good looker. Sweet, at least with either of those you won't have electrical problems :P
This is true...they look fking awesome in real life too. I rephrase: is there a rule that inexpensive electric cars can't look good? New Holden coming out is Prius version 2.
had a customer get pissed because i dont have any 1600mm sink + bench + custom handwash basin in one off the shelf..... it says special order for a reason lol.
the f**k is wrong with people.
looks expensives.
they're not too bad, about 9k new and they only came out last year
and yeah called insurance they said it's okay to take plates off so went back and took em off, also saw the other car had a decent hit
Guest
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
