I think you have to be an administrator to be able to give members' forum access to people, Ham.
Sounds like SAU Vic has started selling 86s haaaaah!
Yo look to the side when you're driving next time. Trying to wave to you on the Eastern last night, you prolly thought I was a cop in a white VE wagon lol.
Wtf that was you?!
The white ve Wagon was tailing me bad on the freeway, changing lanes when I did and quite close. Thought it was some bogans looking for trouble or someone I cut off or something haha
Was close to dropping back and getting behind the Wagon.
Paranoid much?
Go to another dealer
It was about a 12month wait via fleet
So buying it private should be shorter 6-12 months
Nah gg.
Toyota website says 18months too. People gone crazy for this car...
Interior was plastic and the dash reminded me of a hyundai Getz, I guess that's what you get for a budget car...
I'm used to the skyline interior design you can see a lot more money was spent but the car did cost more afterall.
Working on it! Weathers been shit so haven't been able to finish my polish :(
How long left in your probationary?
i see
still on L's dude
been too lazy gonna try booking for next weekend then i guess another 12 months of restrictions assuming i pass :/
yet to put L plates on my bike though lol f**k that
Wtf that was you?!
Paranoid much?
lol I went up alongside you and waved a couple of times, then resorted to pushing you off the road. Your peripheral vision sucks! Knew I'd have the cop look going on though, I'd have been para too.
yeah you do, but christian has told the admins that club execs are not to be mods, hence ash's hands are tied. i'm sure if he could ash would have at LEAST richo as a mod.
I didn't wanna say it, I think I've said enough
lol... dude the only person on the forum that thinks mad82 should be a mod is mad82. :rofl:
Gold isn't a light lol, it's just yellow!
Was considering gold levers but I think it's a bit much...they would really stand out and I'm going for a stealth look with minor gold touches. The shades of gold on different parts are also difficult to match; you can only really get away with small gold touches if the shades are different.
Lol Richo should be the moderator.
And lol
lol i see all. As the saying goes, if you dont swear once whilst driving, you are not paying attention.
Commodore tailing up behind me, then changing lanes, driving parallel and waving his arms then drop back behind and continues tailing.
Not sure if....shaking arms from a rage moment or a friendly wave haha
Guest
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
