and the best bit...
i got to the post office @ 8:50 and they are all ready to go, but the doors are locked.
@ 8:55 the guy walks up to the door and puts the key in the lock, looks at me, shakes his head and walks off.
then they are all standing there looking at their watches doing NOTHING untill 9:00 and 59 seconds when they finally open the doors
and the best bit...
Please tell me you shot them
and the best bit...
minimum wage is the worst thing that ever happened to this country.
and the best bit...
Lol that's what you get with any government service. They don't need your business, they doing you a favour lol
I had the same thing happen to me in the city at 8:55 @ peter stevens.. needed to buy something the doors were open I walked in they said they're not open yet.. had to wait outside for 5 minutes if I didn't need motorbike gloves badly then I would of just walked away
got bored
removed rear pegs
lol I did this today too, looks so much better. Also chucked on aftermarket front indicators...pic coming soon Rim haha.
Caught the bike mod bug, badly -_-
In other news, ALDI are selling bike helmets and jackets lol, $69 and $99 respectively...would you trust them :/
who was the last to write a complaint about speeding fine? need details of what was written, missus got caught
i sent one off about a month ago, pretty much did what alex said, still waiting to hear back
Write letter explaining issue, admit fault, show remorse, state driving history. Complete
Exactly what he said. Works a treat provided previous 3 years are clean I think
Cool thanks
Yeah typical stuff like that to be slow in replying, would have a few letters coming to them I would say lol
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
