whilst the actual personal enjoyment level would be quite low (dose thumbs).
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
(dose thumbs)
fox.jpg?w=548&h=359
So question for those who know things about club rego. I know it says 25 years for manufacture of the vehicle, does this mean it doesn't go off the model of the vehicle eg 1989 R32 will be able to get club rego before 1994 R32?
Well that is annoying :( Jamie can have club reg 5 years before me dun dun daaaa
Are you going to be interest in club reg through SAU VIC?
why do i keep seeing mohomo's car referred to as widebody on my fb feed
i aint seein no widebody? or is rolling ya guards flared these days?
His widebody comments are in reference to using GTR guards
I have heard rumours that if the car is based off an earlier model it can get club rego. For example, if you build a replica of an AC cobra, even though its brand new it is based off a 1960's car.
So going by this theory, if you build your 1994 r32 to replicate a 1988 r32 then you should be able to? lol
From vicroads website;
The Victorian club permit scheme allows members of car clubs (including motorcycle, trailer/caravan and machinery clubs) that are recognised by VicRoads to make limited use of historic vehicles on the road network.
A club permit can be issued to the following vehicles in the following categories:
  • Veteran vehicles – manufactured before 1 January 1919;
  • Vintage vehicles – manufactured after 31 December 1918 and before 1 January 1931
  • Classic and Historic vehicles - manufactured after 31 December 1930, but more than 25 years before the date of the application for a club permit.
These categories can include trailers and modified vehicles such as street rods. Vehicles which are replicas of vehicles in the abovementioned categories may also be issued with a club permit.
I was thinking classic skylines, I wasn't aware that SAU VIC even did club rego :) Hmmm yeah that's the grey area I was reading Pat, not sure what the go is there I might send off an e-mail to someone at classic skylines to get it clarified.
what if i was to say that my R33 gtst is a "replica" of an R31 GTSR jsut a REALLY bad one ;) ... who decides on this?
Guest
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
