Yeah was baycorp I think...didn't pay a cent of interest..Cant complain..
exactly... you did well considering what could have happened
also you provided a perfect case study to show the system works :P
i wouldn't bother with the split dump, not worth it at such low power levels, by the time you need it you have an external gate anyway.
i picked up a dump, front and cat for $300, tomei dump, trust front and nfi what cat it was.
those aftermarket turbos expect even 2nd hand to have to pay, my ef3 2nd hand was still $1600
Hmmm, yeah. That's why I was thinking wasn't on my immediate to-do list. Haha yeah some good second hand parts would be nice!
Haha yeah. Should probably include MAP2.5 to that list. I think I'd be happy with a 9 turbs however, dat response.
The other funds sink is the minor other supporting mods like bov, gauges... Maintenance stuff.
Aaaand of course sussy and wheels, and an e9 rear bar. Also I'm thinking nose chop.
So many plans xD
oh yeah and re evo... probably e7 best BFYB imho... 230awkw from just I/C piping, 8MR OEM turbo, fuel pump, full exhaust, boost solenoid and stock ECU flash.
I have most stuff... just need the turbo and LICP and i'm ready to go, so far have spent about $500 (secondhand stuff)
Yeah. Some 7s sold for some good prices. But I'd probably aim for a bit more, hence an 8. Not to mention other little nice things... like bigger fuel tank :P
3xe or whatever they're called do the licp for under $100 I think, with all the joiners and clamps too.
Brand new was cheaper than any other second hand I could find.
Yeah? Last I checked hot side around $150, cold side around $280... But as a set I think he does < $400 for both. But yeah like I said, x3e was what I was looking at for this :thumbsup:
What's wrong with the e7 tank... It makes you feel like the car's fuel efficient cos it only costs $50 to fill :P
see it's just not worth the hastle...
e85 will get me to what, 250awkw vs 230?
and for that I need to do injectors and make huge efforts for fuel
that's a lot of effort for less than 15kw/tonne
I feel it'd push more than 250, if pushing 230 w/ 98, though...
it's worth getting the tune etc... but TBH I ended up running the 33 on 98 most of the time due to CBFness
290rwkw is enough for daily duties in a gtst
Yeah I fear the ceebs will flow through me lol
Like buying an fc hako etc etc
from discussions on evo oz it seems to net around 250 w e8MR turbo and 260 w e9 turbo
hmm, what sort of boost is that running?
there's a caltex with e85 on my way to uni, so i think i'll be sweet! also more or less on the way to work (sliiiight detour). only drainer is if i need to go in the other direction haha... although dat dual map tune for worst case scenario...
Guest
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
