havnt spoken to her yet. but judging by her FB I think shes "seeing" someone..
Doesn't mean you can't put in a word for me.
Can you at least send/MMS me a pic of her again, I totally forgot what she looks like.
ill speak to her tonight.. i have to find out whats happening with the cash anyway. i didnt end up getting it. ill message you after
DRIVE [sOUNDTRACK]
Performer : Various Artists
Label : Lakeshore Records
Release Date : October 11, 2011
Composer : Cliff Martinez
TRACK LISTING
1 Night Call
- Kavinsky & Lovefoxxx
2 Under Your Spell
- Desire
3 A Real Hero
- College feat. Electric Youth
4 Oh My Love
- Riz Ortolani feat. Katyna Ranieri
5 Tick of the Clock
- Chromatics
6 Rubber Head
- Cliff Martinez
7 I Drive
- Cliff Martinez
8 He Had a Good Time
- Cliff Martinez
9 They Broke His Pelvis
- Cliff Martinez
10 Kick Your Teeth
- Cliff Martinez
11 Where's the Deluxe Version?
- Cliff Martinez
12 See You in Four
- Cliff Martinez
13 After the Chase
- Cliff Martinez
14 Hammer
- Cliff Martinez
15 Wrong Floor
- Cliff Martinez
16 Skull Crushing
- Cliff Martinez
17 My Name on a Car
- Cliff Martinez
18 On the Beach
- Cliff Martinez
19 Bride of Deluxe
- Cliff Martinez
:yes:
Saw the movie Horrible Bosses last night
Be careful the dentist doesn't put you under then takes nude pics of you.
Just sayin.
LOL, dentist is done and dusted, I've got infected wisdom tooth.
Would need to remove left side first then right side. $550 each side, earliest I can have them removed is 14th December - Am going to ask them if the earlier is possible in few weeks time.
On the bright side, it isn't as steep as I'd feared and gives me enough time to save up along with few stuff I want to do...
kadir needs to stop whatever shit is going on with dezz and alex, and its not like alex and dezz are provoking him either.
at least fords look nice from some angles, this is just boring giving each other shit, and its not funny. because it isn't mohsen.
Is that what I did, Michael? I humiliated you? Oh my God, I'm sorry.
humiliate me? You'd never be in a position to humiliate me, but it's good to have a dream.
lol saw that episode not sure why they bother having doors get smashed every episode
probably why they are made from cardboard. lol
Was gonna say, looks like balsa wood....
Like Alex said, he's not even worth the tiny amount of effort it takes to reply to his woeful attempts at insults
Good to hear
Did any more info come out re vettles tyre comin off last night? Was a rather boring race all in all webber could have done better but a 9 sec pit stop will do that to you
Where's next race?
Guest
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
