Money.
For pair of steel wheeled turbos, PFC, injectors, afm, exhaust, labour money to fit these plus nismo clutch I've got sitting in garage for a while.
And many more things such as swaybars, arms, tyres for the rims, alignment, hicas lock bar.
It doesn't end!
I meant by just removing the boost restrictor in the mean time. Would only take a few minutes?
ok the lease rules are oldest model allowed is 2007/2008
only found evo ix 07 which is like 40k pfft
where is nick he will know of a 2007 IX for cheap
Go the Emo!
Yes, it'll take few minutes but with exhaust, will give you better results with minimal restriction.
I had 302rwkw and 270rwkw GTR before this one, I'd want more power than just boost restrictor pulled out.
Because a evo would eat a GTST for breakfast
No doubt about that, it would run rings around a gtst.. but just the sound of a straight 6 is worth holding on to.
Then again i am biased and would probably never own a 4 pot as a performance car, just the idea of modding a 4 pot sounds too funny.
Edited by Flynnn
You Guys remember my remark about Shan getting his beloved doggy stuffed and keeping it forever..
Well I found a stuffed German shepherd in the garage last night. No joke, I don't know how it got there...
But it's a fkn baws.
Tell that to the worked 8MR i met last week LOL
I'm talking stock vs stock, because I'm guessing Pauls looking at just leaving it standard? Obviously more expensive but you get a newer car.
Put money into any car and it can rape any other car..
One of my S15s is putting out 285rwkw on E85 :nyaanyaa:
It's all relative...
Pics or ban.
and to be fair im not buying the evo cos its got tons of power or its super quick
buying it, or looking at it cos its a nice all rounder
my gtst has 240k and probably 160rwkw and i call that quick enough
2012 GTR to do the 1/4 mile in ~10.6-10.7 seconds. Are you positively annoyed friend?
http://www.insideline.com/nissan/gt-r/2013/2013-nissan-gt-r-first-drive.html
Meh, current model ZX14R does it in 9.8 :P
Guest
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
