If it was a factory option only then get your mate to Go to Knox and demand it to be repealed. If not go to formal complaint and add another to his file
+ 1
Don't be like the sheep and say oh well and take it up the anus
A few years back I got stalked and pulled over by Pettitt inside knox (next to the drive through bottle shop near the MultiLevel Carpark / RSL)
He got me to pop the bonnet and went through the engine bay, pointing out things that his junior officer should be checking on any import, how to tell if it was turbo or not, etc... ffs go learn that shit at the academy, stop wasting my time with it!
Ended up getting away with nothing, but it still took 15 minutes of my time and made me late for the movie and I was doing absolutely zero wrong with a completely stock (exhaust only)
*sigh*
Put an official complaint in anyway, say that he was rude and confrontational and would not listen to logical reason about why it is not a defect (standard option for the car).... no doubt the police minister will come out and defend him in the media again saying "To my knowledge, there have been no complaints made against this officer in his time on the force"... when that is complete BS.
and starting at 300,000yen/pax, that is down right ridiculous.
I went to google and typed in "300,000 yen to aud" and the first result was "Is 250-300,000 Yen per month enough to live on?"
*sigh*
So this guys a full blown F&$K wit????
Like import hater???
Mud flaps!?!?!!!
Do you lift Matt?
Judging by your Avatar you do
Awesome pic. Great size. Look thick. Solid. Tight. Keep us all posted on your continued progress with any new progress pics or vid clips. Show us what you got man. Wanna see how freakin' huge, solid, thick and tight you can get. Thanks for the motivation.
Do you lift Matt?
Um........ Glad you noticed? :/
Need to use the currency code, works great
Guest
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
