I have had 3 sets of fake rims, (drifteks, varrstoen's and RG tek's) I have put them through their paces and they have not been any different to the genuine ones except for the wank you hear on forums
all those shots you see of f**ked rims are from accidents that would have destroyed real rims anyway.
end of the day, I have bought real rims and fake, and these days i'd rather put my money towards other shit :P
So owning real wheels is wank?
Just cause you think from your point of view, there is better money else where spent?
I was going to go to WTAC this year...
Since I didn't go up there doing some rough calculations of expenses, travel, fuel, accomodation, food, drink, tickets etc I figure I've saved $1000...
It's logical that that should go directly towards my car mod budget right?
I'm thinking:
Alloy Radiator (suggestions?)
Oil Cooler (with thermo and filter relocation, suggestions?)
New Tint, I've just removed my old blue bubbly tint... everything is so clear now, but so bright!!!
I ran 17s on the XXRs, 17x9.75 +24 iirc and had 255/40
sup
is it just me or does every evo 8 have a different shade rear bar?
ive looked at so many and i think in all of them, the rear bar is a different tinge/shade compared to the rear quater panels
surely not all of them have had touch up / spray work ?
bumpers are always a different shade as it's plastic compared to metal, and there is something with the paint when it is applying so the shade is always off a little
I had teins, they were ok. But I would just spend the money and go BC coils, there could be a chance you get knocking front struts like I did. Iirc it was pretty common in 7s
already knocking lol
not at all... the whinging I hear on forums is wank.
Real wheels generally look better and perform better, but people need to get off their high horses about them.
like the flack I copped for unsprung weight of fake wheels in a thread........ in a 300+rwkw 1400kg car lol
end of the day i'm not chasing 10'ths and neither are most people on here
i'm sure you can see where i'm going with this jamie :P
Haha!
I just wanted your opinion, nothing personal against you.
I didn't mean to sound blunt.
and where would one purchase a Koyorad locally? What thickness is good for a 33. keeping the stock thermo shroud etc? Keeping in mind its a daily with occasional track use... My water temps are getting up a bit too high on the Dyno, and came up a bit too fast for my liking when I was at Sandown.
Would also be good to have a bung in it for my water temp sensor....
Kudos have them for about the same as what they cost from the US now
http://www.kudosmotorsports.com/catalog/koyo-radiator-53mm-aluminium-koyo-type-nissan-skyline-r33-gtr-gts25-gts25t-gts4-p-1064.html
Bung for the stock sensor or bung for aftermarket one?
kudos are very good and have helped me a great deal. Also happens to be 5km away from where I live.
There we go free plug for u Andrew ;)
When someone my size is able to lift and carry 2 x 18x9.5 with rubber at once, then you'll see the value in some quality forged rims
Maybe its just because you lift brah?
Dont know if there is the same room as a 34
But I was able to fit a 52 or 58 can't remember which one, whilst still retaining the shroud
The one in Richmond or Springvale? Need heaps of stuff
He works at Richmond
And on the topic of real vs fakes
If Richo can't tell much of a difference between his light weight enkeis and rota's on the track, and that he also trusts the integrity of the rim to hold up at a track, then its good enough for me :woot:
Paul Cahill in his 32R, one of the fastest guys in SAU VIC also has run Rotas with no issue
Guest
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
