think of the oil/grease/fat, not to mention raw onion and bread is often not good for digestive tract.
I prefer to live on a Canine diet: no chocolate, no raw onion, no garlic, occasionally raw meat, 3 week old eggs or off small goods.
also take a page from the seagull diet: no Panadol, seeds and chips.
Are you young? Happens all the time such bs. What engine did ya get? The 3.2 is awesome
Ill be turning 30 this year, I did want the 3.2 but it was a little out of my price range sadly.. Especially when extras came into play.
The 2.0 TFSI is what I went with, Quattro is pretty much one of the reasons I chose it in the end also.
Nice one! Keep oil handy the audis drink it like no tomorrow for some unknown reason!
As for service I got abused at audi was like :/ and when I bought my Lexus they kept trying to sell it to my mum and gave her the paperwork to sign fkn muppets
Speaking of Lexus the new rcf looks amazing
RCF has some good boy racer feels :P. Also 5L V8. If it's pitching itself against the M4 though, I think I'd rather the M4. From what I've read/seen. Which isn't too much; too far in the future for me :P.
I have heard things about oil, so yeah ill see how it goes :)
oh wow, yeah they always target the parents when you take them with you, i found the same thing lol.
managed to get free servicing for 3 years / 45,000kms, they picking up rego / stamp duty / ctp / 3 year road side etc all that stuff..
+1 rcf!
I thought you were a youngin!
RCF is apparently going to be as good as the m4 - having said that the RCF will likely have 10 times the features of the m4 for less but be interesting to see when its out i think the lexus looks hot as wont be in my budget though so hoping the 3.5ltr 6cyl one will be *fingers crossed*
+1 rcf!
nice deal save quite a bit with the servicing etc, the best feautre IMO is unlocking the car at night / underground carpark and the welcome home lights up car turns heads like no tomorrow lol
love dem gimmicks.
love dem gimmicks.
Another draw for the M4 is that it will still come with a stick shift. Also I think I saw that the M4 was going to start from about $62K or something (in the US, of course... :P). So I'll have to move there if I ever want something like that soon :P.
But that's true, with the extras the pricing battle will be interesting. You sure you wouldn't stretch for dem V8 sounds tho? :P
What are these welcome home lights you speak of...
Yeah but I ain't into them stick shift nota daily car and the autos are awesome now days like the c63 etc
Welcome home lights are when u unlock the LEDs the driving lights tail and all interior lights come on
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
