the auto barn fire extinguisher comes with a bracket. just drill out the hole a bit (get a workshop to do it. if they wanna charge you for 30 secs of work go somewhere else) and bolt it to the rear seat tab. then screw the other end into the floor pan with a self tapper. its not gonna go anywhere.
blue and red contact from news agent = win. All of $5ea for a roll of 5M, that is a lot of triangles.
fire ext easy to do with a bit a metal from bunnings, plus something to cut it with and something to drill holes with.
What's the red triangle for? Says nothing in the sup reg about that. Only says blue triangle and tow stickers
got the stickers... NOW. for the extinguisher. lol. grant, i come to donny you do for me? i bring you a blow up doll.
Don't have drill or drill bit strong enough to drill metal...
But tafe do have them.
trackday at nationals alvin?
Hey Cass, odd I know but can you measure number plate brackets on front for me please?
It's metal bracket that goes underneath the top of the mouth of bar, it's screwed into the reinforcement bar. I need to make some so the number plate doesn't have to be zip tied on lip...
Guest
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
