  • Replies 150
Nah rally stuff makes you look like a muppet. There you are trying to read the notes and the bloody photographers make it look like you are trying to find a spot under the dash to hide.
Second one from Wanneroo. Note the multiple black lines & the Emo with the fail understeer.
Edited by djr81
Lol, Lancer shitbox doing what they do best !
Tim's balls are that big he's probably reading a novel while I "drive"......
Here I think he was looking for one of his many women in the spectators;
And lol @ understeer of fail on the Evo..... boring cars. Fast. But boring.
What sort of times were you doing with the supra at lakeside Harry.
Care to share what was done to it?
It ran a best of 60.7 the only time I drove it on the new surface at lakeside. That was on KU36 tyres.
It was a 93 RZ 6speed, so it was the lightest of them, but still fairly hefty at 1530kg on the weighbridge! without me! I also ran it very light on fuel at Lakeside. About 1/4tank and would top it up with a jerry can during the day. Never had any fuel surge problems.
The early V160 Getrag had shorter gearing than the later VVT models with the V161, which probably helps.
All it had was Tein Flex coilovers that were pretty shagged by that stage - the RR was leaking and started axle tramping that day at Lakeside. The nice Rays GramLights with 245 and 275 KU36s. It had as much camber on the front as we could get with the stock adjustment - about 2.5degrees. Castor wasn't very much because of the way it was adjusted you had to compromise between static camber and castor, we went with max static camber. Zero toe. I didn't let them touch the rear alignment because it handled so sweetly the way it was, so no idea of what setting were there.. I found it was very sensitive to ride height adjustments and ended up with 600mm rear and 595 front from the lower edge of the 18" rims to the gaurds.
Brakes were the small/early 2/1 sliders with TRW Lucas pads which worked great.
Engine wise it had a Pod filter and cat-back exhaust. Still had the stock side mount intercooler and boost was standard 10psi. I ran it in TTC mode because it gave better midrange grunt than sequential and more linear response exiting corners. The next owner had it dyno'd as it was and made 186rwkw before he went single turbo.
To beat the factory speed cut I just disconnected the odometer at the track.
i still think it would be faster than my current 200rwkw 1250kg 180SX if I put proper semis on it like the 180 has...
Edited by hrd-hr30
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
