I hope online is just as good as the standard game. I noticed that the stocks in insurance company's raise and fall depending on how many cars your crash or destroy.
I went without crashing and then purchased them then went on a smashing spree and they raised a fair bit.
im on 360 add me if you guys like UrNightmare369, only up to about the 6th story mission, been doing side missions like the tow truck and random world events they are so fun, saved a chick by killing 3 guys trying to attack her :P
That chick didn't need saving she was trying to lead you into a ambush
Beat the main story today...what a game!
Am promptly planning to do another playthrough, just gonna make a few different choices here and there and want to see if I can rack up the 150mil to buy the golf club
one thing thats really getting on my nerves is how many bullets you can take. been killed so many times now running an enemy over, getting out of the car, seeing on the radar that he's not dead and me getting shot up during the animation it takes to get out of the car. spend so much money on armour, and clothes and it all changes/disappears when switching characters.
also navigating indoor spaces. people have to elegantly run around and try to change directions and all you do is just miss doorways and run into walls. been like this for red dead and GTA4. grrrr.
still having a lot of fun though
once you finish the missions is it like most GTA games where you're now sick of combat and fetch missions and isn't as fun anymore?
i don't think so at all, just started a second playthough! And yeah, just wait till online drops!
I went with C for the end. Strongly considered option A.
I lol'd at the little psych profile the game gives you at the end.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
