  • Replies 886
It depends what smoothing was used in the dyno program, it averages out the peaks and troughs for a better looking graph.
Yes this. Dyno dynamics (well my one anyway) doesnt have smoothing. The maps can be as smooth as u want and u can get these little irregularities in the dyno plot
I was actually referring the fuel maps having massive holes in them, the new maps are nice and smooth.
The turbo was built by stao to run 20psi, am I wrong to think it would do differently to what it was built for?
Just making sure that you understand that you just don't get any turbo and ram whatever boost you like through it.
Also, don't bother upping your boost until you have your boost control sorted with a decent electronic boost controller like a Gizzmo, or something that is intelligent.
Dude give it up... His car is fixed now, it turned out fine. Its tuned to its appropriate best and he's learnt from his mistakes.
Continuing on with crap like that is just making yourself look like a fool. Please stop.
http://www.skylinesaustralia.com/forums/topic/381108-1999-black-rs4s-12000/
eat my arse Scotty :rofl2:
did you notice that thread was started in October last year? its been for sale for a long time, as you can see the price is set according to my lack of need to sell it, just for sale as its just my occasional car and if someone wants it for that price it can go. i love it as a car and dont really want to sell but its just not financially viable to drive it to work, my wife cant drive it as the clutch it a little bit hard for her in traffic and its too rough for her to be a passenger in while my child is in her belly.
Edited by lilcrash
  • 3 weeks later...
No boost controller, Tried a turbosmart boost t on the dyno and it wouldnt run any more boost without heat soaking. Nothing has been touched, the day after the tune it started making over 20psi. I have since gone over every vacuum hose and inter cooler hose and not found a single problem.
You need a boost controller with linear correction, eg with mine it will dip from 19psi to 14-15psi, but if I add 35% extra gain from 4000-7000 rpm it holds flat until about 6800 when it genuinely runs out of flow and dips down to about 16-17
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
