As per above. I have had to remove my Cusco brake stopper because it hit my Plazmaman plenum. I have seen strut braces that have master cylinder stoppers in them but have no idea of which brand.
Any takers?
The NISMO strut brace has a built in brake stopper
Just looked up nismo strut braces and couldnt see any master braces
I have aNISMO strut brace and definitely has one. I bought it new about 4 months ago. I think that I bought it from www.greenline.jp if you find it on their website it says that brace comes with the brake master cylinder stopper.
Any takers?
Cusco do one. I got mine from Greenline but had to email them & ask as it was not listed.
Same as the normal strut braces except the drivers side mount has the bits on it for the brake stopper.
Get a buddy to press the brake pedal in your car while you look under the bonnet. If he pressed hard you'll see the brake booster moves. It's flexing on the mounts.
A stopper essentially braces this and can give you a slightly better feel.. Not a lot of difference in my opinion though.
i had the same thing with my plazaman, cusco strut brace and separate cusco master cylinder stopper - was rubbing - put in a decent engine torque damperner, one with a little bit of give - never had a prob with hitting or rubbing since and not screwed engine mounts or anything else either
R32 or R33? R32 clashes on mine.
Not paying 3 times what my engine is worth for a ti one either :) May attack my Whiteline one with a welder and see what I can butcher up
Thanks people
R32 gtst just like yours
Have a bit 15mm gap between stopper and Plenum when normal after few track days noticed a small rub mark wearing away was from engine torque pushing engine over under load. Engine dampener on that side worked a treat no probs at all.
Maybe look at that?
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
