I'm thinking of putting a surge tank on my 260rs with a single 044, just looking for ideas of surge tanks and where to mount it,
If anyone has pics or other reccommendations please post your ideas,
I looked at fitting a walbro but is way too small for the in tank cradle, have thought about a nismo replacement but they are a lil expensive, the cheapest i have found one is $499 delivered from n power on ebay
Considering the Nismo is good for 450-500kw its worth every cent. If you want a cheaper pump get the deatchworks or aeromotive pumps, they are a highflow pump in a walbro package and can be easily fitted into any tank with a few hoseclamps.
The M35 comes with a built in surge assembly. Surely there is somewhere you can fit one under yours? If you decide to get one made, use the stock pump intank and run 044's off the surge.
My surge tank (3L) is in the car but it is very noisy although I have insulated the cover (was really noisy before). I have a walbro cable tied into the stock cradle and a Bosch 044 out of the surge tank. I would try to put the tank under the rear seat (under the car) if possible.
044 is $200 bucks, Surge tank, 150-200, new braided teflon lines + fittings (so your car doesnt stink like fuel everyday) - $200
Go the Nismo
Go the Nismo
(NZ$) my surge tank was $150 Walbro $200 Bosch 044 $300 Cover for surge tank $300 Insulation and carpet $100 there'e a grand without fuel lines and hours of labour. Unless you're into serious track work (don't laugh, I can't afford another track car) a really grunty in-tank pump is the way to go.
044 would fit perfect in the cradle in my tank but i've heard they dont pick up too well on the last 1/4 tank,
I also want to run e85 on occasions so i want a pump thats compatable, is the nismo pump ok with e85?
on what volt rating does the nismo flow that much ???? also with the walbro or deutch you need a direct power feed of around 13volts or more to make them flow there recomended settings . 040 can have picck up probs under 1/4 tank so just dont run that low surge tanks are the way to go if you want to make any sort of decent power its just a good sound investment ! i run a intank walbro wich feeds my surge tank and an 044 pulling from tank all mounted underneath my car near fuel tank and as far as e85 goes looks like a lot of the guys run twin 044 s
bosch 040 235l/hr @ 5 bar 12.5 volts 260rwkw (safe)
bosch 044 330l/h @5bar 12.5 volts 330rwkw (safe)
and from memory walbro on 13.6 volts 270- 280 on normal pump feed volts around 230rwkw
I didn't see the point in changing my set up.
I left the lift pump (in tank) as the stock GTR pump. These can be picked up for cheap to
2 litre custom surge tank that cost me less than $100 to get made
Single 044 that I picked up for 190
Various fittings and lines totaled just over $150.
Basically I never wanted any surge to happen on say a hard launch or on a track etc etc. Its good peace of mind for me as it removes one weak link out of my cars chain. I'd go the external set up any day
I ran the Tomei on ethanol for over year with no problems, same as Nismo apparently. They should be good for over 400wkw with e85 and will work on stock voltages if you want.
Im currently running twin Walbro's and have been guarenteed they will be fine with e85, from the testing various workshops have done.
I found this thread on fitting a 044 in a r32 GTR, the cradle in my tank is exactly the same, this would be a cheaper way of installing a 044, would there be any issues with mounting it this way?
none at all worked for me for 3 years, I only went ext surge so I could run twin 044 pumps if you only need 1 pump this is the best option. Fittings for 044 cost $25-30 they were on ebay when I did mine.
I think one 044 will be sufficent as i dont want anymore than 330kw at the moment, the 260rs is still a fsmily car & the mrs drives it most of the time,
Is it nessesary to have 2 to run on e85?
You need to deside what you want to do 1st because you will need to change a few things and retune to run e85 remember the mods to the fuel pump cradle are ireversible.
Have been prowling the web on different fuel set ups and found a lot of write ups on the honda forums in the usa about guys setting up 044 directly on line without surge tanks.
Standard or walbro in tank to standard fuel lines then 044 in the engine bay between fuel filter and rail,
They all seem to make very decent power and stories of any type of failures or problems due to being set up like that.
Has anyone else got a set up like this or can anyone comment on pro's or con's of doing it like this?
http://www.honda-tech.com/showthread.php?t=2389237&highlight=Fuel+Pump
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
