Because I keep forgetting to check up on what is going on with everyone's race car builds and progress, and most of the motorsport guys wanting their builds in here.
I figure, Why not have a thread where people can talk shit about their tin-top builds / race results / blow ups / event coverage.
I spose I will accept the two fancy pants kids with their Radicals too :thumbsup:
So yeah, Who is doing what and when?
https://www.sau.com.au/forums/topic/385320-because-race-car-thread/
So atm I am in talks with nsw production touring cars about getting the Supra homologated for Group 3E.
If that all goes ahead the long drawn out build will start...eventually.
If they knock it back (is a possibility due to there being stuff all info about them, and the Workshop manual is only in Japanese >_< ) I'll have to have a long hard think about what to do with it.
Could either convert it to the 3L Turbo A spec (swap the 1JZ for a 7M-GTE and find a Turbo A intercooler...lol good luck)
or just run it in MRA/iRace
Finally getting my p.o.s tuned after about 2 years of owning/building it, hopefully ready for the start of 2012.
Still lots of little things to finish up, tow hooks, under trays, vents, brackets, windows, etc.
post-19425-0-63339700-1323551397_thumb.jpg post-19425-0-26707000-1323552358_thumb.jpg
Edited by CameronBNR32
Haha the motor and suspension will be left alone
A cage is just 1 thing lol
Why would you bother with an MA70 supra when the engine/suspension is to be left alone?
They are a nugget car after you've thrown 20k at them let alone with 2k spent.
Go buy an s13 (s13 not 180sx so it can be run in IPRA) spend 2k on the car 4k on modifications and go racing.
Happily ever after.
Does it still comply with Targa regs?
No it doesn't, when I bought the car it was, over the last 2 years I've pulled it down and rebuilt/modified it with no rule book/class in mind, I plan to use it in sprints/time attacks type events.
I have just left the stickers on all this time.
Looks great, what state are you going to be tracking it in? If it is nsw you should come do some sscc or mra events with us.
Sorted... and how about some pics of this abomination you now own Zebra. You have to be the most bipoloar person in the forum wth regards to plans, cars you buy etc :)
Still could not PM for some reason, left a comment.
Haha yes. I think that too lol
Problem being that most of my previous projects have been expensive and needed a lot of work or been unreliable
This one I picked up for 4k has semi decent suspension, nice lightweight enkei wheels and being the R model has bigger sway bars and a torsen LSD and recaros from factory.
Only major hurdle is that has a built auto with 2800 stall
But should be able to sell it for the same money a 5 speed goes for. So will just be up for a clutch and a pedal box which are fairly cheap.
Will never be quick (neither will I for that matter) but should be reliable and a bit of fun which is all I want
I did seriously think about an S13 or a cheap skyline
But I have always had a soft spot for the a70's (and pop up lights lol)
Will add a couple of pics when I jump on the computer
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
