hey guys im looking at buying a new pod filter as well as the whole intake system mainly because of sound purposes, but along those lines i want one thats durable and not one that just sounds great but fails on me after a month. I've been looking into it and im hearing a lot of different things about which one is the best but i need one suited for me and my circumstances, hopefully the following questions will help me:
1) Currently being on my P's, is it legal to have one just as long as it is enclosed?
2) To prevent hot air from being sucked in, what else might i have to do besides installing a CAI and ensure maximum efficiency?
3) Is it better to have a dry or oil pod filter?
4) Arguably what is the best intake system for an r34 gtt?
Thanks guys
https://www.sau.com.au/forums/topic/386490-air-intake-system/
Oiled, I run one myself in my GTR for 2 years and no AFM problems. Panel filter that is, I believe there are some things you can do to the airbox, I vagually recall with R33 airboxes you could take off one of the side pieces which Nissan put there to stop induction noise?
The blitz panels are good too Ive heard and half the price of the K&N, although I did run a K&N and never had issues with it :) I'd be running a stock box on the car if its stock. Only reason I am not running the stock box now is because there is no way I can make it line up with this turbo and intake pipe.
yeah its a stock box. I've heard a lot of good things about the Blitz SUS pods but never heard anything about the panels, do they make any noise at all? Or are we to confirm only pods make noise
http://justjap.com/store/product.php?productid=16424&cat=&page=1
End thread.
Makes induction noise a lot louder and sounds good on my R34 GTT. I had it on the standard turbo and it sounded good, now I have it on a 280rwkw setup and it still sounds good and flows well. My tuner Trent said he has seen 400rwkw setups using this intake so it definitely flows well. Bolts straight up too.
http://justjap.com/s...424&cat=&page=1
End thread.
thanks so apexi is the way to go, but not all of my questions have been answered. i know its a dry filter but do i require a cold air intake system with this?
Does not matter what filter, you will need a cold air intake to feed air to the pod for best results.
If you change to an air pod, leave your standard air intake feed to channel cool air to the pod.
Like so.
yes.
Go for a DIY one. Look in the DIY section for CAI boxes. Bunnings perspex...
Like so.
cool that makes sense :) ill probably just have to get a custom box for it so i dont get defected by cops
I run a K&N panel filter in my GTR, I really heard no induction noise until I swapped out my stock turbos for garrett -9s.. now i hear them spool up from 2psi onwards whereas I didn't even really hear the stock turbos make any noise until 7psi.
ok i think i have a rough idea of what i need to get the most out of my pod filter
1. Apexi power intake kit
2. Carbon fibre cold airbox designed for the r34 gt
3. JJR Silicone Induction Pipe
4. High flow air feeding pipe that will feed cold air to the engine, something like this http://www.ebay.com/itm/220761678179?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
can people give me their thoughts and ideas on this? thanks!
Why bother with the silicone induction? If you got stock turbo, just sleeve up the original with a metal pipe in the middle. Carbon fiber box will cost you too much. Get one made of a cheaper material, plastic or metal, then have it wrapped in carbon fiber vinyl. Those memory pipes are good but eBay wants too much for them.
4. High flow air feeding pipe that will feed cold air to the engine, something like this http://www.ebay.com/...984.m1438.l2649
^^ With what you have listed
Do this:
Apply what WYTSKY has done when you get your customised air box.
Credit goes to WYTSKY for the DIY write up.
I used:
$8- 90 degree intake pipe from a vn commodore in Pick Pay n Go
$4- flexible black funnel from Bunnings
$12- 6 pack hole saw bits up to 100mm from Bunnings (were meant for wood but they were so cheap and I only wanted to use them once)
$3- Rubber edge to cover up the bare hole from Clark Rubber-"Cool Clarky" if you please :P
All up = $27
The whole process only took me about an hour and you only need very basic tools.
Tools required:
Hack saw
Drill
Wire cutters/Tin snips
Maybe a flathead or phillips head to undo a few plastic screws on the underbody
The Steps:
1. Once you have found a Vn Commodore intake pipe, you will notice one side is longer then the other. I ended up cutting it down to about the same, so I could fit the funnel on it and just fit it all into the front bar.
2. Once the pipe can fit in under the front bar (keep testing to find the right size) you need to cut the funnel down to attach it onto the pipe. The funnel is used to attract more air in the direction of the pipe to flow straight to the pod. It probably isn't 100% neccesary, but for $4 who cares?
3. Use the hack saw again, cutting the funnel about halfway through, possibly with a little bias either way. The next step you want to do is measure how much you need to flare the inside of the funnel so it fits snuggly over the pipe. At the moment, the smallest part of the funnel should be able to fit inside the pipe, fit it in and see how much you need to flare the funnel.(It should be about a centimeter)
4. To flare the funnel you will probably need to make about 10 tabs with the hack saw around the smallest end of the funnel, each about 1cm deep. Once the tabs are made, grab a lighter and make the tabs just a tad warm which will make it a little easier to bend the flares with your fingers. The final result should make the small end look like a flower, which will then allow for the pipe to fit in.
To hold the pipe and the funnel together, use an adjustable hose clamp to tighten down the open flares over the pipe.
At this point your piping is now complete, it is optional if you want to use some fly wire to stop any bugs/leaves going up the pipe to your pod, I was not to worried about this because my pod is already a filter so I don't think it matters. You now need to make the hole in your engine bay.
5. Get your pack of hole saw bits, I used a 90mm size which fit very snug. Adjust where you want to place your hole, I decided to make it right in the middle under the pod. Attach the hole saw to your drill and start off very slowly. (From what other people had said I was weary of using hole saw bits that were made for wood, but they were a quater of the price of metal ones and I only planned to use them once.) After you have made the rough outline of where you want your hole start pushing down a little harder, then just keep holding it there, that way the teeth on the hole saw bit wont go blunt as quickly. I did it this way and it took me about 2 minutes before I could simply peal off the perfect circle like a metal can lid, plus I still have plenty use out of the hole
saw!
6. Once your hole is made you need to put the rubber edge on, and if you have it handy, spray some fish oil to stop rust(if you don't, don't stress, the rubber edge stays on nice and tight!) To get rubber the right length slowly cut it down in educated guesses, because it slips in deeper to the edge then you think and you end up needing more or have a part where the circle is not complete. I strongly recommend you use this rubber edging because it makes the hole look a lot more professional and hides any imperfections you may have made making the hole. ( in the pics the circle looks a little lop sided because the rubber had not been put on properly yet)
7. The final step to do is adjust the angle of the pipe a little, just so the funnel is pointed right in the center of the hole of the front bar and try to point the 90 degree pipe slightly down so dirt and water can't fly up as easily. I simply used a few hidden cable ties and found a few holes off which to angle them by.
Hope you all enjoyed and also check out my heatsheild tutorial!
Enclose pod with box then make an opening under the box for the CAI / Hose to connect into to feed air to pod.
As far as i am aware you are allowed 0 modifications on your p's!
A pod whether in a shitty home made box or no box is still a modification and is easily detectable by ear and illegal.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
