Ive been looking for something like this thread for a long time! its exactly what a skyline needs if your running a pod, that cold air is quite important!
But, isnt it illegal to drill that hole in the position where you did? (So ive been told) I have two 3" holes in my 32, currently occupied by the intercooler pipes confused.gif but it would be nice to get some sorta setup working in there before my next tune
thanks everybody for all the help and ideas! thanks brett i checked with vic roads to, any mod to your car under your p's is illegal pinch.gif im just gonna go ahead and buy a panel filter instead, looking at the nismo s tune sports air filter
From what i have read on here i would not waste your money on a nismo filter, saw a test on here ages ago that showed the factory filter is the best one available, at best i would (and do) use and non oiled k&n and im making 250rwkw so that will be more than fine in a non turbo.
The car you are driving is illegal for a start.
Just get a K&N panel filter.
Good enough for me @ 365rwkw, good enough for you. About $80-$90 or so. You could probably find cheaper if you shop around
The GTR airbox & snorkel design is much different to the GTST one, the GTR is much more free flowing. What works for a GTR will not always work for a GTST/GTT. Best thing to do is probably put the car on the dyno, get a baseline run with the standard airbox, snorkel and filter. Do another run with the lid & snorkel removed, then another with the filter out. This should let you know if there is a restriction there. For a GTST/GTT I would say the answer is yes there is a restriction. You can always try and put in a new filter with/without the lid & snorkel and see if that makes a difference. I have heard that the standard Nissan filter is quite good for flow. I am thinking of using these and replacing them regularly like I would copper plugs. Standard Nissan panel filter is dry too so no oil on your AFM.
A pod should provide you with the best flow as with the right one the surface area will be much larger than the panel filter. Not to mention the base of the airbox in the GTST/GTT blocks a considerable area where the AFM bolts to it.
LOL sorry mate i didnt mean to say gt 't', its a gt 25 non turbo. really i find it hard to believe how a panel filter that can be bought from autobarn is better than something made by nismo specifically for japanese vehicles, but if everyone is saying K&N then i guess ill go with it!
Yes i realise that.
But on a bog stock (what we thought was a gt-t), it's fine. A gt-t airbox really isn't that bad if you have a look at one. They are a good piece of kit. Hence people make 270rwkw through them with nothing more than a replacement filter.
Now it's a GT - even more so unimportant.
Just to make sure.. I wasn't having a dig, just wanted to mention some observations I've made with a lot of looking at the standard airbox setup for the R33 GTST. I believe the R34 GTT is nearly the same apart from a slightly different snorkel design. I did buy GTT & GTR ones at some point in the past to see if I could use them instead. I did not. I have had the airbox lid removed at a 200rwkw level and it made a noticeable power change and altered the Air/fuel ratios, so it definitely changed things. I have modified a standard airbox quite a bit and it still didn't make any huge improvements so I am going to look at some alternative options.. :ninja:
I'm pretty sure Stao and others found the airbox a limiting factor and had to cut holes in the lid to flow enough air.
As mentioned though, being a GT, it's not going to change much in this situation.
Ye - on a dyno with the bonnet up :)
Take it out onto the street where the airflow & snorkel are working how they were designed and it's a different story. Dyno fans really don't have the same effect as travelling @ 80-100km/h+
There was a graph about 2yrs ago with back to back. Difference was around 6-8rwkw IIRC on the rollers on a 250rwkw setup. (R33 gts-t airbox it was, using a K&N Filter). Difference ye, but it's not major and certainly not worth the undue hassle you end up with. Depends on the person if they cbf'd with doing a proper CAI setup (that is still illegal).
LOL.. yeah there is definitely more to it than simple lid off :)
What gets me a bit is the 'cooling panels' that people put over their grill in front of the radiator support bar. These basically block the snorkel flow.. I did start to muck around with fibreglass one that had the snorkel sit sitting low but didn't end up finishing anything.
<br />LOL.. yeah there is definitely more to it than simple lid off <img src='http://www.skylinesaustralia.com/forums/public/style_emoticons/default/smile.gif' class='bbc_emoticon' alt=':)' /><br /><br />What gets me a bit is the 'cooling panels' that people put over their grill in front of the radiator support bar.  These basically block the snorkel flow.. I did start to muck around with fibreglass one that had the snorkel sit sitting low but didn't end up finishing anything.<br />
<br /><br /><br />
Depends on what diverter plate and what car. If you have an R32 GTR bonnet and grile, the diverter plate sits below the top grille bar and so air goes over the top of the grille into the snorkel space. Which would be great if R32s had a snorkel!!
I'd be wary of using an oiled filter on an engine that runs a MAF (and a 10+ year old one at that) due to the possibility of oil getting onto the AFM wire. I also would not be cutting holes through metal for that ghetto CAI mod (which incidentally would likely not work with an open pod anyway)
the stock airbox dosen't look that restrictive TBH, pity no one does OTR intakes for Skylines haha
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
