Hey Paul, if by oil analysis you mean take a test tube to someone for scientific analysis then probably not. I wouldn't know the first thing about that
If you mean visuals of water contamination + photos, of course! :P
Plus, I'm not sure how relevant my analysis would be to you, I only own a lowly gtst, not a full house 2.8 GTR! :P
Ethanol and fuel is same same. It gives no fark for car type or capacity haha.
I made the change to E85 a few months back. I have been using the Penrite sin range for years.
After going to E85 I put some fresh Penrite sin 20/50 in and dropped it today after maybe 3000km.
Oil looked fine. My car is making 270rwkw and has nearly 200k on the clock. It gets looked after but does get a boot full every now and then. To be honest I can't fault the Penrite stuff. I have tried RP and the Motul oils and my car just doesn't seen to like it as much as the Penrite. My 2cents anyway.
i run pentrite with E85 as does everyone i know when they are running E85. Seems to be the oil of choice and doesnt seem to break down as quick as some of the others under these conditions..
if you do some searching on the net you will find that ALOT of people say the same thing so thats a winner IMO
Ok so dropped out the Edge 10w60 over the weekend. Here's my super scientific analysis: It was fine. It looked and smelled like any other oil I've changed before.
I copied the technique I read in Performance Imports magazine by stirring up the oil to see if there was water separated from the oil that would show up as white stuff where you stir it, but I saw nothing.
Note: this is a 270kw r33 gtst that is driven every day, South East QLD weather, lots of extra urban trips when cold < 5 mins driving.
Pics:
20w50 is too thick for dailying an SR20 with just a squirt here and there...
honestly i'd look at something a little thinner, especially on the cold viscosity... penrite have a 10w50 syn dont they?
Edge 10w60 is probably the most one common used in vic
Well it looked pretty good to me? How can you tell if it's broken down?
I would have thought with the type of conditions I operate my car in, it would have gone bad if it was ever going to.
I drive plenty of short trips with a cold engine, where fuel can apparently wash past the rings and into the oil etc and break it down. I do no highway kms, all around town driving. Stop start.
heaps of people use it however I havent ith e85, only 98... personally I prefer motul 6100 15w50 with e85 so I can't really comment personally...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
