  • Replies 742
Pro class is getting out of control!!! Think I'll stick with open class where the cars still resemble the street cars they started as
lol yes it is out of control. I think that is the whole idea of having open and pro classes, one being more controlled than the other.
The pro class is exciting if that is your thing. innovation and engineering freedom allows for some truly fast cars.
we are sticking with the crazieness of pro class!
funny thing is the fastest car, Cyber Evo, wouldn't look out of place in Open Class. Its just nowhere near as radical as some of the things with bullshit crazy aero that still can't match it. No doubt it has very good well developed aero, but its not the 'out-there' stuff we're seeing from some of the locals. Hopefully they ban front wings before someone goes all 'Rado' on us over here...
As much as I really don't like Evos, I can't help but like the Cyber car.
Don't be fooled Harry, the cyber car has so much aero going on you just don't know it. Very trick.
They have numerous wind tunnel testings. etc. they have tried to make it look subtle even down to not painting the side skirts below the obvious more 'OEM line'
I won't list the features on the aero they have tuned but if you knew aero and you looked over the car you would know it.
plus its bullshit light and well setup over years of testing and has a very dedicated team.
check out the aero pics below. These guys don't even have bolt holes hanging below the full carbon floor, they have it suspending completely from above without and impediment to flow. this is just the top surface of the cars floor.
also check out the subtle but very trick air flow from the wheel wells. don't be fooled as i said, this is way beyond an open team.
how do I know?
I studied the car, I studied the people, I studied the theory and I discussed with the experts.
These guys are smart.
A lot of the local cars with 'crazy aero' have not had the years of tuning and setup mods the cyber team have endured. don't be too quick to judge. most only had the cars bolted together only just in time to make the event last year.
I've seen and heard all the stuff about their aero before - its no secret. Its just that they keep the car looking like a car. Not adding 2 feet of strange platypus bill out the front or wings off the sides or a couple of feet of the world's biggest diffuser on the back up to the height of the taillights. I've got no doubt all that stuff that fella designed works, but it looks crap, and Cyber shows you don't need all that outrageous stuff to be fast.
Edited by hrd-hr30
I think that the craziness of Pro Class is great. It allows free thinking and ideas you could never implement in controlled motorsport categories.
I agree that Mark Berry's R34 and the MCS S13 look completely ridiculous from a " i want m car to look like that" point of view but in a logical way they look kinda cool
But I also like that Open Class stays true the cause a bit more. I think a few further regs might need to be put in place to really keep that differentiation. \
Pro Class has one appeal, and open class has the appeal of still looking like the original car. Pull the wing and splitter of most cars in Open and take the stickers off and them look like JDM styled street cars. We decided to keep JET200 Open class so that Motive DVD viewers can still relate to the car and buy the bits it uses. A Pro class car is too out of reach for 99.9% of our viewers and out of reach of my bank balance! lol
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
