Hey guys not sure which turbo will suit price/power/stealth
im after a turbo which is undetectable by cops, has more power than stock and isnt too expensive and has minimal turbo lag.
ive been looking at this hyergear g1 400hp rated turbo, its a direct bolt on for rb25 and its $1250 i have a jjr split pipe coming too so i wanna hit it all in one go.
rpm range for boost is 1500-3600 rated 20psi
link : http://digi-hardware.com/atr43.html
can i have this turbo on running 8psi like what my current turbo is running now and should it be fine? or do i need pfc with it?
current mods :
- 3.5 cat back
- return flow FMIC
- HD clutch
- BMC panel filter
the final power figure im aiming for eventually is whatever the injectors can throw out safely so 220? with 80% or 90% duty? not a gun on this part.
Thankyou in advance!
https://www.sau.com.au/forums/topic/386913-upgrade-turbo-but-not-too-crazy/
Absolutely agree with the above. Hypergear's hiflow of your existing turbo will be the closest thing to your stealth requirement and cost less than the ATR43. But don't upgrade your turbo if you're not going to upgrade everything else. At minimum you want Nistune, fuel pump, intercooler and 14 psi, + turbo upgrade or you are wasting your time. And that's just to take you to the limits of your stock injectors. Time for you to read a few sticky threads I think.
Sorry forgot to mention the main reason for this post, my turbo is making loud noise like a sander on a piece of perpex. it gets louder and more noticeable as it pass 2-3 mins of consistent WOT.
under normal driving conditions there no unusual audible sound.
thanks guys.
so best option is to get my turbo high flowed? what will the power rating be with bigger wheels on it? turbo lag etc?
2 to 3 minutes of consistent WOT... Where are you driving that thing, across seven airport runways in a row?!
thanks guys.
Where is this place I want a go
i had this high pitched noise on my old GTT, thought it was poss the turbo but in the end it was the FMIC which had a slight leak around one of the silicone joiners. So i just pulled it all apart and put it all back together making 200% sure all was nice and snug, and got some good clamps and ditched the ones it came with. Norma ones i think?
i had a highflow hypergear on my GTT as well, nice bit of kit. Stealth, punchy and plenty of fun in a rwd Skyline. 250rwkw ish on 98. 280'ish on E85.
But like the others, no point getting the turbo, dump etc without getting something to tune it. As you have a R33, you're better off getting a power fc i reckon.
no doubt ill be gettin a pfc just wondering if i should rebuild my one or be looking at something else. whats the differences between a rebuilt highflowed r33 turbo compared to a hypergear g1 turbo in regards to power/response/ boost/cost etc.
He was actually driving an R32 with an RB20 in 3rd gear and at 3,000 RPM. It was slightly uphill.
Like others have said you will need to upgrade more if you are changing the turbo, seems a waste to upgrade the turbo and only get 1/10th of the upgrade it can offer. This is what id be doing
Fuel pump
Some sort of injectors if not an adjustable reg
3 inch dump
Aftermarket computer. Weather it be a nistune or power fc
Maybe a EBC
Z32 afm
Turbo
Tune
But doing all of that if a cop sees something he does't like he will defect you, so really if you went for a garrett a trubo is going to be the least of your worries as he will probally get you for to low etc.
sweet guys thanx for all ur help. Im gonna just drive it around like a granny till i save up for a hypergear highflow, pfc, injectors, fuel pump, 3" turbo back, ebc, z32 afm or map sensor. and a sexy tune!
sex!
thanks again guys.
-split dump
-venom hi-flow cat
Get those done first.
What sort of CAI are you running? If you haven't already upgraded that yet do that before you go altering the turbo. Even if it is just a good panel filter in the stock box.
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
