Import Monster Sauvic Deca Motorkhana - 2012 Round 1
Proudly Presents:
Import Monster SAU-Vic DECA Motorkhana ROUND 1 of 4 of the 2012 DECA CHAMPIONSHIP
When : Saturday 25th February 2012
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. HERE!!!
NO PAYMENT, YOU WILL NOT BE ON THE LIST
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Ryan Bell Disclaimer'.
Event Schedule:Here
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 20th February.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
  • Replies 378
Entry List:
1. Ash Cosgriff R33 GTR
2. Import Monster
3. Leon Stapley 180sx
4. Ryan Bell 180sx
5. Ashley Stacey R33 GTR
6. Luke Schulze R33 GTS-t
7. Trung Nguyen Chaser
8. Chris Taylor 300zx
9. Daniel Taylor S14
10. Harsh Gupta R33 GTR
11. Bradly Insley XR6
12. Mark Ryan R33 GTS-t
13. Hamish Hampton R33 GTS-t
14. Clive Small Lancer
15. Jake Lowry S14
16. Paul Stephenson EVO VII
17. Kat Glebova EVO VII
18. Mario West EVO VIII
19. Jett Benson 180SX
20. Simon Henman R33 GTS-t
21. Gary Swift 180sx
22. Sandeep Abeywickrema 300zx
23. Alex Skrekovski EVO X
24. Steven Skrekovski MX5
25. Russell Cunningham R32 GTS-t
26. Jordan Sudarevic MX5
27. Ryan Gorzella RX8
28. Rhys Cantrill R33 GTS-t
29. Daegal Harris S14
30. Johnathon Oliver VX
31. Jakub Radzikowski 180sx
32. Brad Archbold Evo VIII
33. Thai Long Chieu Corona
34. Jad Luciani R33 GTS-t
35. Matthew Nisi S14
36. Daniel Somerville STI
37. Andy Theobald GSR
38. John Packham S14
39. Elvis Ayala R33 GTS-t
40. Laith Graham R33 GTS-t
41. Brendon Pryor R33 GTS-t
42. Damien Nebel STI
43. Mark Rodgers STI
44.
45.
46.
47.
48.
49.
50.
Reserve:
1.
2.
3.
4.
5.
Can I enter in a Daihatsu Terios? It's designed extra narrow so it can fit down certain streets in Japan, combine that with its high center of mass and it'll be great on the skidpan! Lets not forget the 65kw at the fly + AWD for some limiter launches!
gonna shoot some money through and my entry tomorrow or monday :)
i hope the NA can actually do something haha
N/A's kill it on the skid pan.... soooooo much easier than high HP cars
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
