But in saying that backyard builds vs workshop builds. There is only one way to put together a bottom end. The correct way. Regardless if its a glamorous workshop with tip top race cars or somebody in a shed such as d'anallo performance who has a rb25 30 running into the 8s. Quality workmanship is quality workmanship.
My theory on a workshop is. If you're going to open a workshop you should know how to build an engine properly as a minimum. You learn how to do that in your 4th year of trade school. Iv had bad experiences with a certain shop that did an abortion of a job on my car. I basically redid all their work to how I wanted it and its yet to fail me (still using a stock bottom end). And all that work was done off a hoist in a small garage.
I do agree with you on experience. Trial and error plays a big part when pushing the limits.
I still don't understand why "professionals" can't do the job that they're payed for correctly. We as customers pay the 100% price yet we dont get 100% effort or quality. Same goes with "tuners" what irritates me is some workshops won't put as much effort or care in a tune if you built it elsewhere and braught it for a tune yet they will go to the moon and back when you have them build you an overpriced engine. Work should be done 100% regardless of where the car came from.
Won't name any famous tuning shops, but I've seen for myself copy and paste tunes across similar cars.... and funny how "they were all tuned from scratch" ra ra ra.. and tuned the cold start, etc... car probably saw about 15 minutes of dyno time and copy and paste of a bin file... $1100 later, see you bye.
Spend less time dealing with workshop lies and empty promises and more time tearing it up.
On another note. If the stock quality is so awesome why are so many rb 26s failing due to oil starvation? Or any engine for that matter? Not saying its poor quality. But saying a built engine with all the trimmings is/can be a lot better.
A lot of this is attributed to people putting sticky tyres on them, doing a number of hotlaps and pulling massive lateral g's
So modifications would need to be made to suit the application. Like baffled sumps and what not. Always room for improvement. If those mods were made prior to raping the car on the track would the stock internals last? Edited by LTHLRB
far better chance i'd say
nissan didn't design the car to be exiting corners at well over 100 kph with R comps on all 4 paws after 10 hotlaps
the oil pickup isn't even in the centre of the sump lol
1998 r34 gtt 4 door sedan fact manul.
Rb25det neo
Pon b cams
Pfc
Walbro 416 LPH pump
E85
Gtx 3076r . 82 machined out int gate
Uprated actuator
Split fire coils
4" dump into twin front pipes(120mm) in hks super silent exhaust with hi flow cat
Standard clutch
Made 325rwkw 20psi wheel spinning due to using 10" wide super sticky dun lops on 40 psi, dropped to 20 psi but were still way to hot.
Next is upgrade clutch and change rears then up boost
Rb25
Etm manifold gt3582 with t04z wheel and highflowed 4inch exhaust
Microtech lt16
Spitfire coils
Forward facing plenum
850cc injectors 2x 044
Process west 96mm thick cooler
Jim berry full Monty clutch
Eboost 2
Didn't make the dyno only street tuned and cracked ring lan and ripped engine mount apart
Edited by paul_psi
could you tell something was broken and what had caused it, eg boost/revs or both? im bit confused when mine happened cause even on 5 good cylinders it was pulling hard still, just idling rough.
Edited by AngryRB
so is forged pistons the only answer to breaking ring lands? planning rb30det ( 9.5:1 and 3076) and want to be confident I wont break another ring land. I don't like piston slap so forgies not ideal for a street car..
Edited by AngryRB
Keeping the cylinder pressure low and knock under control would help with extending the stock piston's life. Even ethanol can't remove detonation, especially as the temps start to rise.
Piston slap shouldn't happen if you choose the right piston materials, as long as the bore is machined correctly.
Hey guys.
Im making 425 at the rears in my GTX3582R setup.
Neo cams kinda look gay on paper, is it worth upgrading them for when I go e85? I'm looking to make 500 on a stock motor and head gasket.
Hey guys.
As in the duration? cos the lift is higher. Remember that they are solid lifters so can run a more aggressive ramp rate for a better overall result, so not as bad as they seem. Edited by superben
Depends on the cause, if you have knock then you'll still break them they just might take 6 months instead of 3 months to snap. If you are breaking them due to genuine high cylinder pressures eg 3-400kw then they will help, though broken ring lands in these motors are almost always due to knock, you might have an issue that doesn't show up during dyno time that is causing the problem.
Piston slap with forgies is only due to big clearances, it is a tight call between slap and the piston siezing, just make sure the expansion coefficients of the pistons aren't too excessive and then you can run tighter tolerances, maybe give RIPS or race-pace a call and see what they recommend piston wise (and clearance) for minimal slap.
Hey guys.
It's probably worth the upgrade if it's a number you are chasing as the only other options are even bigger turbo's or more boost
depends on which cams really
I just didn't want to go E85 and not make the most of it by not having the suipporting mods.
I'd rather have something that comes onto boost harder in the mid range than chase a specific peak number,
  • 2 months later...
Stock RB25DET (head bolts, head gasket, internals)
hks 256/264 cams and ex cam gear
nismo 740cc injectors
apexi pfc with a z32
garrett gt3076 .82 turbo with tial 44mm gate
GTR intercooler
Greddy plenum
Tomei 500hp lift pump with a 044 feed
Nismo fuel reg
23psi and BP Ultimate
BIG thanks to Trent and Cat from Chequered Tuning. Glad to see there are still legit people in the Auto industry.
Edited by LTHLRB
  • Like 1
R33 Rb25det Stock engine
Brae exhaust manifold
HPVA 50mm external gate
HyperGear SLSS2 Turbocharger
600x300x75mm Intercooler kit
3inches turbo back exhaust
1000CC injectors
Power FC
E85 Fuel
Final result of 356rwkws @ 20psi
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
