im leaning more towards the +30*/35 because i want flush fitment not poke, plus the larger offset will clear big brakes if i ever upgrade.
im only running such a small tires because i have limited funds and dont want to buy new ones yet when i already have some 235's with 80% tread
Offset doesn't determine brake clearance. Spoke design does.
  • 1 month later...
Hey Guys,
This has been really helpful to read through, I'm ordering rims this week from Work, getting Meister s1 3 piece 18x10+31 and 18x11+29
going by what you guys are saying this seems ridiculous, but I would like to know what you think of offset for front/rear, as you can tell I'm going for a big 'dish' look.
I have Yellow Speed coil overs, will be getting a Type R body kit from viva garage, and universal flares to help fitment. Standard breaks for now but looking into a Brembo or Project Mu kit shortly.
Getting my head around offset has been hard, and I'd love to see some pictures of wheels to compare different offset types. I know what look I am going for, so much criticism about how much work I'll need to do, which I am aware of, I just need a basis to go off, and you all seem to know what works/what doesn't.
Cheers, Ellie :yes:
PS: this is the look I am going for, any ideas on the offset?
Edited by elleNEO
those wheels on David Lai's 34 are 19×11 -1 and 19×11 +3 pretty sure
if you have a non GTR 34 without any guard work you can fit 18x10+15 with a little poke or around +30 will make it more flush,
ive got 18x10+35 on my rears at the moment (non GTR no rear guard work), they sit a little in with no spacers, 5mm gets me flush and 10mm spacers get me just a tiny bit of poke. but with +35 my rim hits the coilovers if i slam them too much so id advise +30 at the rear max,
for the front i have 18x9+30 but i have GTR front guards so they have plenty of room, wish i went +15 on the front instead. but spacers will help me fill the gap anyway.
thats just what ive found with my 34 anyway, heres some pics for reference hopefully helps a little
5mm spacer in front and rears
How about this setup on my GTT, getting a sweet deal on a forged set so I thought I would consider this....
18x8.5 +30mm Fronts
18X10.5 +50mm (with 2" lip) Rears
car has BC racing coilovers coming, other then that the suspension is stock right now.
Will these work with the appropriate tires? would I need any spacers to make the rears fit better?
+ 50 on the rear is way to big for 10.5's, im pretty sure if i ran them on my 34 id need 30mm spacers for the rim to clear the coilover which would = massive poke resulting in major guard-work or a defect. (less offset should give you a bigger lip too)
im not an expert, just going off my past experience. and it all depends on how you want your wheels to sit.
im using BC coilovers as well and as i said in a above post my 18x10+35 on the rear hit my coilovers if i lower my car too much so i have to run spacers.
if you want a flush look id aim for 18x10+25/30 in the rear and add 5-10mm spacers to give you desired poke/flush look
im not too sure about your fronts as i have wider guards so i have more room then you but 18x8.5 +30 sounds like it would sit pretty well
hope that helps you
thanks for your help!
I actually went to see them, they are actually 18x8 in the fronts and 18x10 in the rears.
Since the seller had the sizing off I imagine he also was not correct with the offset being at +50 either. I could not find on the wheel the offset either.
I will be test fitting them shortly to see how they actually fit on the car, its the only way to be certain.
  • 3 weeks later...
I'm looking at a set of d1rs in 18x10+41 rear and 18x9+25 front I have rolled guards and nismo s tune suspension, I don't want camber and ridiculous stretch on my tyres, but I want the guards filled those offsets should clear okay and have room for my brakes still?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
