I was watching a NASCAR race the other day... 165MPH... Slowest corner on the track... Top speeds around 185MPH...
Fucking NUTS!!!
must've been a short track. the big ovals they will hit well over 200mph. top speed i've seen was near on 210mph (over 335kmh)
nascar has moved to efi.
the sprint cup race i watched a few weeks back had a bit of a tech thing on it and the car they were showing then didn't have an ecu. they said it didn't even have a fuel sensor.
  • Replies 245
the average lap speed for pole position at the 2012 daytona 500 was over 194mph, even with restrictor plates. race lap speed is higher because of drafting. but the corners there aren't that sharp. they still sit on around 190mph through the corners, and hit just under 200mph at the end of the straights. at tracks like texas they don't run restrictors. they drop down to 175mph in the corners but get back up to just under 200mph. they also rev up to nearly 10000rpm at texas, while daytona they only rev up to around 9000rpm (because they are flat to the floor pretty much the whole time)
the daytona lap record though is from 1987 though, with an average speed of over 210mph. pretty good for a dirty old v8, lol
No idea what track it was, but even my ass puckered up a bit when one of the guys exited a corner in a massive slide... And held it...
They were only revving to a bit over 9K from what I was seeing. Around 9.5 IIRC.
They are going EFI next year I believe.
One thing you can say about nascar is they have remained faithful to the formula.
NEK MINNIT
All spec car series are shit.
EOB.
  • 3 weeks later...
On the engine front... it has been reported in AA that the KR-Nissan-Nismo engine team have signed off on the powerplant.They have chosen the 5.6L DOHC V8 engine as used in the Nissan GT-R GT1 project in Japan.
How they go about reducing the capacity to 5L or less is anybodies guess. I assume they will sleeve it down rather then throw in a new crank but who knows.
Holden look to be preferring a Chev crate engine on the basis of cost. So you have Nissan running high tech, ridgey didge race motor, with twin cams, 4 valves per cylinder and lots of modern race design nice to haves VS Holden looking for a cheap crate Chev engine to build and spec up.
I am guessing the Chevs are going to get some extra displacement if they are to have a hope of matching the Nissan in anything resembling a short sprint event.
Seems odd that Ford and Holden are contemplating an engine change. Surely the change to COTF is expensive enough in the short term without taking on engine development
And Rick Kelly is off to the USA for a car show to promote the Altima...so I guess thats what will be wearing Jack Daniels war paint next year
Ford has a tasty 5L 32 valve engine they have been using in grand am sports cars for a few years. Making an easy 500hp in near standard trim
That series works well with Porsche, Lexus, ford, chev etc all running spec engines producing the same performance
Would be easy to implement for the supercars out here
Be interesting to see unravel.
Anyone know what the GT1 spec Nissan donk power/rev wise
I also find it funny that Holden went to the HMS engine because the chevs were down on power compared to the D3 headed Fords. But now they want to go back to chev after all the money spent on copying the ford motor and creating tooling/machinery to cast them
I would like to see ford adopt the FR9 and detune it down from NASCAR spec that way the Holden guys could run the current 13deg chevs and would open the gates for Toyota and Chrysler
http://theage.drive.com.au/motor-news/new-nissan-to-debut-on-track-20120404-1wbka.html
Someone should probably tell Nissan you don't go into motorsport to make money.
Also, what if they don't win a single race?
lol. the shame. that's twice this week I've been wrong :P
Unless I've missed the point, the altima is a fwd shitbox that is going to replace maxima in the road going line up? The replacement for a bluebird...or a 200b?
I wonder if nissan oz are aware of a model in their JDM lineup called "skyline"
  • 3 weeks later...
I like the fact that they're claiming it has more road going parts than the other two...
Yet, they're changing the floor pan, and a completely different engine to what you can really buy at the dealership...
Also, Duncan, are they making a 4 door Skyline at the moment?
looks like the V8's will be back at Eastern Creek in August this year,
Yes, will be good to see them back at the creek especially with the time attack cars being there later in the year too !
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
