"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
Hi guys
sorry i haven't been on here for a while i only got the chance to jump on and post a couple of pix of some manifolds we are doing, we have had people ask us prior for doing manifolds with out wastegate ports to run on their setup's so they can run the wastegate direct of the turbo housing, so we are now making them also with out ports for Rb20, Rb25 and 26, We are also doing the Rb26 setup with a T4 split flange 3 collectors on each side if you are running a split pulse flange on your turbo, the 26 setups come standard with 38mm port if you require large we can also make you one larger for extra cost.
Prices are :
Rb20 / rb25 / rb26 manifolds with out wastegate ports $369 AU Shipped to AU
Rb26 split pulse setup with 38mm wastegate port $369 Au Shipped to AU
Rb26 spilt pulse setup with 40, 44, 50mm port $469 Shipped to Au
  • Replies 384
Do all ur manifolds only come with 2 threaded holes on the flange plates?
when i was at school flange meant something totally different ;)
Still means something totally different.
I can never manage to read flange without a bit of a grin.
Ok guys, for those that are interested I got my high mount T3 external gate Kelway manifold today so here are a few pics. He makes his own collector, he doesn't buy the pre made one.
Does the wastegate mount right there? I thought you're supposed to have a decent distance between the top of the wastegate and any heat sources, that looks like the diaphragm is gonna get pretty toasty?
It does mount up there. I'll take a pic of it dummies up. All the info I've found is to keep it short for boost control. It points the top the gate away from the turbo so it will be fine. If it comes to it The gate is a Tial mvs that has water cooling function if you want.
Edited by slippylotion
here is a few photos of my rb25 manifold that arrived a few days ago
replaced it with my cheap chinese thing.
has a 50mm port for wastegate and im running a gt3582r turbo
just waiting on dumpipe 2 be modified 2 suit.
Mine rocked up today, was sent monday and here today, not bad considering some stuff i ordered in Aus isnt here yet...
Looks pretty darn good for the price, have seen 6boosts etc so have something to compare it to, cant wait to bolt it on and see how she goes.
Glad you guys like the manifolds, we are doing some changes currently we will have a couple new things out in the next couple months also we will be doing a couple of low mount ones with and without external port, would any one be interested in them?
Yes i would be , low mount , 40mm ext gate , cash waiting :D . I will be fitting a td06 to it so there should be plenty of room around the strut tower . Can you ceramic coat them by any chance?
I'm interested in purchasing one of these for my rb20, looking for a high mount T3 with 38mm 2bolt flange, how much am i looking at posted to aus?
$359 incl shipping if you like one PM me. thanks
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
