does it have the cover for the master cylinder compartment? Mine never came with one.. i have the one for the battery though.
Let me know.
You need a LHD battery cover. And I think there was some custom work involved, but Cam (iamhe77) can confirm.
  • Replies 162
What happened to the original Stagea that you needed the motor AND wiring?
+1 Don't you have the old engine and loom still? I could be interested in both.
yeah, G35 battery cover and shroud.
Need to cut about 10-15mm off the top of the steel frame so that the cover can sit in position.
Also recommended to make up two small brackets for the holes at the top to clip into and make it secure.
Looks awesome though and will definitely be an early addition to my PNM35.
http://www.skylinesaustralia.com/forums/topic/311501-m35-brake-fluid-panel-cover/page__view__findpost__p__5147723
http://www.skylinesa...ost__p__5147723
as in this ?
http://www.ebay.com.au/itm/New-JDM-Battery-Cover-2003-2007-G35-/230681766789?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b5b46b85
Same thing, except for the other side.
We want their battery cover to complete the look and they want ours....
That's basically what you have on your car. G35 being LHD has their battery and brake fluid areas opposite to us
Interested in the drivers seat.
What is the condition of the leather? any cracks or tears?
Need the plastic card holder under the visor also. Mine has a broken leg.
Do you have the security blind for the boot? Mine is torn.
Thanks
Thanks
Cargo blind is sold, posted late last week and arrived by courier today. thumbsup.gif
Thanks Chad, appreciate the fast sending of the item.
I'll let you know if there's anything else I need.
Cheers mate,
Jas
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
