does it have the cover for the master cylinder compartment? Mine never came with one.. i have the one for the battery though.
Let me know.
You need a LHD battery cover. And I think there was some custom work involved, but Cam (iamhe77) can confirm.
  • Replies 162
What happened to the original Stagea that you needed the motor AND wiring?
+1 Don't you have the old engine and loom still? I could be interested in both.
yeah, G35 battery cover and shroud.
Need to cut about 10-15mm off the top of the steel frame so that the cover can sit in position.
Also recommended to make up two small brackets for the holes at the top to clip into and make it secure.
Looks awesome though and will definitely be an early addition to my PNM35.
http://www.skylinesaustralia.com/forums/topic/311501-m35-brake-fluid-panel-cover/page__view__findpost__p__5147723
http://www.skylinesa...ost__p__5147723
as in this ?
http://www.ebay.com.au/itm/New-JDM-Battery-Cover-2003-2007-G35-/230681766789?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b5b46b85
Same thing, except for the other side.
We want their battery cover to complete the look and they want ours....
That's basically what you have on your car. G35 being LHD has their battery and brake fluid areas opposite to us
Interested in the drivers seat.
What is the condition of the leather? any cracks or tears?
Need the plastic card holder under the visor also. Mine has a broken leg.
Do you have the security blind for the boot? Mine is torn.
Thanks
Thanks
Cargo blind is sold, posted late last week and arrived by courier today. thumbsup.gif
Thanks Chad, appreciate the fast sending of the item.
I'll let you know if there's anything else I need.
Cheers mate,
Jas
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
