Had to get a noise test done last week, was 92 but have to be 90 or under, to pass the guy made up a 2.5" rear section with some triple flow 2.5" muffler, as soon as i passed i put the old one back on coz the 2.5 looked and sounded poo.
I was thinking about just using a hot dog just behind the cat, will this cut the db enough to make it legal, was told by a mate that an 18" one on his datsun dropped it 10db, hard to beleive since this red back 2.5 i had put on only dropped it 7 db, also will it be more of a benefit to put it in front/behind/in between the mufflers i already have?
Im looking to cut out 4-5db (or more if i can) without losing power.
https://www.sau.com.au/forums/topic/395071-hot-dog-muffler-for-dropping-4db/
  • Replies 46
FYI in car audio type noise measurement (SPL), at the 90db mark every additional 3db is considered to be 'twice' as loud. So 4db is a pretty decent drop, get a muffler as a hot dog will just tone it down a little but probably still read similar.
I have a straight through varex with a hotdog in middle, 3 inch, 100 db open, 77 shut. magical. And my engineer signed off on it. Just dont use wot when closed or bad things will happen. that is unless you always want it quiet
Highly unlikely a hotdog will get you anymore than 1-2db in a proper test.
Need a stock exhaust or a welded in silencer at the rear
In normal 3" form my exhaust did 92, with 2.5" pipe and muffler behind the diff it did 85, that tells me that there is ways to make it legal without needing to weld shit in and resort to using a factory exhaust, what was the phrase i saw you use the other day "smart modding" with the right bits i will get a legal exhaust that will flow the 250rwkw i have and the 300 i will get after a tune.
The hard part is making it height legal and still look good, that will be my next task.
And if you have to do a db test they will probably tell you to change as its not allowed to be adjustable, does not matter what the engineer has signed off on.
Brett what is your current exhaust set up - ie. centre muffler(s) / rear mufflers, diameter and length of mufflers
a big fck off centre muffler is the solution
there's some talk of Borla mufflers here
http://www.skylinesaustralia.com/forums/topic/394860-tomei-extreme-ti-cat-back-exhaust-system/
Edited by Ronin 09
Funny that, even though plenty of cars have variable mufflers from the factory, even taragos
Get a hotdog, you'd be surprised at what they can do. My system has only the cat, a hotdog and the Varex which is effectively a straight through pipe in open mode, which nets about 100db. Surely without the hotdog it's just a straight out exhaust, which would be heaps over 100db...
Same!
When I went for my test the guy said Varex probably wouldn't be legal, I said my exhaust doesn't sound that loud when it's open so if it passes on open can you clear it? He said he might be able to do that, but open came back as 100db lol. It sure didn't sound like 100db.
The legal limit is ridiculous though, the standard system is only just legal and it's quiet as shit.
16-18" x 12" x 8" rear muffler
that will get your 3" exhaust legal easily if you have a decent middle muffler.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
