S A U N S W - Texi, "the Original" @ Sutton Road
  • Replies 219
I've never really been one for skids n stuff. Dunno why just dosent really appeal to me
...............(waits for flaming)
Always been more interested in going quick point to point, problem is I don't seem to be able to get fast launches right so I take of like a granny in a carolla. I need help me thinks
Is there a certain type or size of fire extinguisher we need? I'm unsure what a ' insurance approved fire extinguisher ' is, my friend and I both have to buy one - don't want to get one that isn't approved.
Cheers.
Edited by sweefu
they only really come in 1 size from places like supercheap auto, autobarn, bursons etc..
It will have a metal bracket (not plastic) and have a stamp on the box saying "CAMS certified" or "CAMS approved"
I picked mine up from supercheap for about $30 from the 'outdoor' section with camping crap
It's exactly like belting through National Park. Exactly
cheers N1 and Duncan, thats some scary stuff, too many track days has weirdly made me even more careful through those sections than i ever was pre-trackday..i guess it was knowing how easy it is to lose it and wipe out that made me never look at nasho/old pac runs the same way again. Still i dont plan on missing this thing and will give it my all on the day..well 8/10ths anyway.
Yep that is all you need to do at a place like this, and it really is no different to a tarmac rally. You just choose what you think is a safe pace - if you think 110% like you might on a track, it can be dangerous or expensive.
But if you keep some in reserve and show respect to the track and conditions it is fine.
There are very few places in NSW where you can head along a 1 lane road at any speed you like, no worries abiout speed cameras....so don't miss this!
f**k it, this place is too much fun.
I'm going to get the race car going for this.
Packing spare bearings? :P
Remember, I won't be there to make changes or check tyre pressures for you... :P
Thanks for that, I think I know what to get.
http://www.camsmanual.com.au/pdf/10_gen_req/GQ09_Schedule_H_2012-2.pdf
:D
Trying to coax the missus to bring and drive the starlet.
And trying to convince her friend to come and run her mps3.
I'm trying guys, really I am.
hey why not....Rosie has brought her mazda 3 to a few events, and a starlet finished in the top 5 the first time we ran down there ;)
Indeed, bring the missus and her friend along. This event has actually been almost won by someone in a stock (but stripped) Starlet, but that's because Reece was driving!
And yep, that's my little sister Duncan's talking about. We both did a day at Oran Park way back when - I know I'm not the only one who misses that track... We were in separate groups, and she told me later that she'd spun the Mazda3 and went off backwards at Shell Corner, but she shook it off, waited for the rest of the cars in her group to go by, then got right back into it! With a bit of tuition from Duncan, she built some confidence and really enjoyed the experience.
Oh, and that map just happens to be linked to an article about Chubbs: http://chicanecultur...dney-australia/
And yep, that's my little sister Duncan's talking about. We both did a day at Oran Park way back when - I know I'm not the only one who misses that track... We were in separate groups, and she told me later that she'd spun the Mazda3 and went off backwards at Shell Corner, but she shook it off, waited for the rest of the cars in her group to go by, then got right back into it! With a bit of tuition from Duncan, she built some confidence and really enjoyed the experience. Unfortunately, there isn't anywhere near as much run-off room at the Sutton Road Complex, so have fun, but be wary of your surrounds and be careful!
A couple of weeks ago Aldi had recently dated 1kg fire extinguishers with the double metal bracket for $15ea. Have a look at your local Aldi before trying supercheap/bunnings etc.
Also make sure you get one that's recent, or it wont be any good for cams events if you want to enter any later.
Please do enter the starlet, need micra vs. starlet battle :D
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
