Hi guys, this is my car that Trent's talking about. I might as well address the questions directly :) Apologies for the long post.
It's a 2JZ-GTE unopened except for mild cams (HKS 264s, 9mm lift).
Sky30, your setup is probably most comparable to mine in that you're running a 3L bottom end. TurboS, in the best twin tradition :), are twin GT2860RS with Tial 0.64A/R V-band housings, mounted on a V-band modified Blitz TT manifold, which is a rare item for these motors. Custom fabrication +++ for inlet, intercooler piping and twin discharge piping done by an artist fabricator friend of mine.
I run a customised Snow Performance Stage 3 kit. I make my own mix, spraying ~55:45 meth:distilled water early and in high volumes, 625cc primary and 375cc secondary nozzles. Price wise, the Boost Juice premix retails for about $4/L. Mine costs $1.55/L. No brainer :)
I use a ~10L boot mounted reservoir, and top up weekly, but it would easily last a month. The car is daily driven. I completely disagree with those who find it a "low quality" kit - I am not budget limited, I chose this kit, and my experience is anything but. Nothing has pooled, sludged, or obstructed - although again, my car doesn't sit, it gets driven like it should.
E85 is a half hour drive from me assuming zero traffic, and it's not what I want to be doing on a busy workday or weekend. My fuel setup is simple - single in-tank pump, stock lines, rail, reg, drop in 800cc injectors - as is my engine management (PFC), and for my daily driven purposes, it has been flawless.
My mix is well controlled and stored, and to re-do my fuel system properly for E85 would have been another few thousand dollars, plus inconvenience, and the possibility of fuel smell in the cabin etc from using aftermarket lines - not an option for me, I have a baby seat in back with precious cargo, who, might I say, LOVES the sound of an external gate :)
Before I took it to Trent, I road tuned it, and it was very happy with +6deg timing advance across the board - including at peak torque, with ZERO knock audible. I am big on safety, so we ended up with +4deg of timing advance and significantly richer AFs than the mid 12s:1 at which WMI really starts to shine. Furthermore, 4psi boost increase netted an extra 65rwkW. Any setup making >15rwkW/lb of boost is frigging efficient, and the WMI I'm SURE plays a big part in that, notwithstanding the time and effort I put in to matching all components in my setup. I don't think E85 would yield significantly higher gains.
Finally, an added benefit I saw when I road tuned it. I could run almost 20% leaner overall, and this translated to a direct improvement in fuel economy of 20%. More power, less fuel used = win for a daily driven application :D
To give you an idea of how effective the WMI is - I drove 120km total yesterday, in high ambient temperatures, to and from work and straight to the dyno. First pull on the dyno, NO cooldown time, at my street boost yielded 390rwkW - bang on exactly what it was when I got it tuned previously. As Trent says, it provides consistent, repeatable and reliable results irrespective of ambient temperature- IF the mix is controlled and stored properly. Logged IATs drop from a heatsoaked steady state by over 50% - within 3 SECONDS. There is no FMIC setup that will do this so rapidly.
Needless to say, the car is brilliant to drive on the street ;)
Hope this helps others thinking about going this route. It takes a bit of care, but I would unreservedly recommend it for a daily driven vehicle. Happy to answer any questions as needed.
Edited by shombre
Was thinking about this today, if you found a good glass cleaner with some methanol content, you could run the WMI feed directly from the washer bottle correct? (since most skylines have 3+ litre washer bottles) Leaving the only thing visible in the engine bay the injection nozzle and line.....
And the pump...
The pump on the washer bottle has no where near enough pressure to atomise the mixture properly.
Most WMI pumps are 150psi, with quite a few that are 200psi +.
I've had the nozzle out and its like steam the mist is that fine. And thats how you want it - atomised to the shithouse for the best distribution.
I think it would be better stealth wise to mount the pump, a smaller resovoir etc on fab'd up brackets all in the boot of a 33 with as much as possible in where the battery and fuel tank access is. Then run the hose to the engine bay under the car or something.
I didn't mean using the washer bottle pumps to feed the WMI. I meant using the washer bottle as a reservoir, but still keeping it functional as a washer bottle. I doubt the washer motor would even be able to over-come boost pressure?
so the meth/water mix would be used to wash your windscreen as well if required to? Would the supplied pump be designed to work with the washer bottle though?
If so, I suppose thats an option as well, but personally I would prefer them sperate as long as it all fits in the boot nicely.
Edited by Mitcho_7
I suppose thats an option as well, but personalkly I would prefer them sperate I think.
So you let your car actually get dirty enough that you use the washers? I think ive used the washer bottle perhaps twice in my life. Water/meth tank makes much more sense to me.
And yes you can use it to wash your windows with too. Have you never cleaned glass with metho and a newspaper?
You must live in an area with 0 insect population :(
Just seems like a waste of water/meth to use it on your windscreen IMO
I still think something tidy like this in the boot would be much more appealing.
http://howertonengin...ineering-tanks/
Edited by Mitcho_7
hell yeah thats a sexy little unit Mitch, mount it under the parcel shelf on some drawer runners so you can slide it in and out when you need to fill it
i found this how to interesting
http://www.turbomirage.com/water-alcohol-injection-installation-instructions.html
Bugs at 200kph make quite the mess. There are times the spirited enthusiast will need those wipers to continue lol
Different strokes for different folks.
I was thinking along the lines of GTRNUR, my washers rarely get used, and the tank is huge, maybe not for a track car, but for a "spirited-driving" daily, using the washer bottle would save running lines from back to front and the (small) cost of the tank, and be less obvious than a seperate mounted tank. If the kit has an external pump that runs a line from the reserve to the pump, I don't see how it couldn't be adapted. If the washer motors/bottle etc can't handle metho you could still run water injection alone.
The idea of adding 5-10% nitromethane has me intrigued! Would be cheap enough to do at $75 for 4 liters as you would use bugger all. And how cool would it be running nitromethane (even though the amount is tiny)!
Has anyone here done it before? I understand when nitromethane combusts that one of the outputs is nitric acid, would this damage the bores over time? Would be interested to see if it provided any additional gains in power. I might give it a go in my car when I get it all going.
Add a drop of blue food colouring to the 5lt mix and you can call it windex injection. You can actually use some kinds of industrial glass cleaners too, as they contain up to 25% methanol.
Also this is something else that I find interesting...
http://www.hobbyparts.com.au/store/item/nitro004l/fuelnitromethane/
5-10% nitro is considered safe. Higher concentrations can fall out of suspension, but would probably remain in solution better if mixed with methanol first. There is quite a few threads on the waterinjection info forum about this.
In the concentrations you'd be burning it, nitric acid production wouldn't be an issue.
Also consider that its going in with water and a whole lot of fuel so it blows out the exhaust pretty quickly and at high temperatures. Its not as though its a top fuel car running a 90% nitro mix. No where near as bad as a diesel with sulphuric acid eating its exhaust. Considering the quality of the oils we use and how regularly we change them compared to a diesel, polutants don't stay in the engine very long.
I've been meaning to post this link too:
760whp skyline with direct port water injection. There is a stack of information skyline specific in this thread. Dyno sheets, before/afters etc..
http://www.aquamist....ht=nitromethane
Yeh, I could count on 1 hand the amount of times i have actually used my washer bottle so it makes sense to utilize it for something else. It could be an option if you are pressed for space or want a stealth setup. You will still have the external pump and i know someone suggested to mount it in the guard, but i dont think they like water to much, which could be problematic if its raining...
Im keen to see some people play around with some different setups!
Seriously if you are running that much power your gunna need a pretty serious fuel system anyway..
What I am really interested to see now is a E85 fueled car with WMI..
Will it be twice as awesome, or not really..
might give it a crack if no one else does:)
Thats what i was always going to be doing with the R31, the build has just blown out by yrs..and my brother is doing with his gemini atm, ollie on ct forum has already done it
on his 9.9(think that what it run) sec full street trim vl , stock rebuilt na bottom end to..
Theres a few other kits aswell, coolingmist, devils own etc...i have a cooling mist trunk kit on the stagea, fits in the back area well and plenty of room for shopping and kids shit
cheers
darren
Edited by jet_r31
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
