  • 2 months later...
What you guys think of this as a fail safe device? Seems pretty nifty to me, and can work with any wmi kit.
http://www.aemelectr...ce-1-4-sae-1184
hmmm I might look more into this. I was just about to order a Snow Performance SafeInjection kit for my WMI setup, but maybe this would be better.
I will be selling my Snow stage 2 kit soon, has a warning light and boost reference control. Its brand new, so PM me an offer if you want mate.
Thanks for the offer, but I already have a new Snow stage 3 kit ready to go in the car when I finish putting that together :)
Heres the kit:
http://www.ebay.com.au/itm/Snow-Performance-20010-Water-Injection-System-Stage-2-/390477290989?pt=Motors_Car_Truck_Parts_Accessories&hash=item5aea429ded#ht_1521wt_1133
Thats the same seller I used, same price I paid.
I opened the box, admired the quality, threw out a useless cardboard divider and shelfed it anticipating my build.
Then things happened and I went a different way with my build that doesnt warrant WMI, so its just taking up space.
PM me a sensible offer and I'll have it in the post on Sat'dy morning. Hows that for impulse?
I use the snow stage 2 kit. I have nistune tuned for 17psi without water injection. This is my low boost setting. I run a smidge under 20psi on high boost with water injection, same tune, no knock.
Looking at getting a safeguard of some sort, but for the time being, when I do mountains or after a bit of boosting I switch back to low boost until I can check the water level in the tank. I only have the small snow res, located behind the glovebox. I am always topping it up, paranoid about another grenaded engine lol
Not the same gains as a proper tune with water (timing increase and prob more boost), but def noticable. I'd say at least a conservative 20seat-of-pants hp, but I expect more than that. Don't want to make outlandish claims with nothing to back it up tho.
Thats fair enough. I will be doing a WMI kit soon but not on my own car. I'll update results, might just do it your way and see what the extra boost has to offer.
Tune completed!
Red line is the stock ECU with an SAFC
Green line is the Nistune Z32 ECU re-tuned for ~9.5 psi
Orange line is the current tune with the WMI on and some minor adjustments.
Although there isn't a massive gain in power, the tune doesn't rely solely on the WMI to make power, if the WMI does fail, it will leave the tune close to the edge, but not mean an instantly lunched engine. Had a bit of trouble initially as the nozzle is simply too large for the power the cars making, after dropping the pump pressure down a bit it netted worth-while results.
The good bits:
-Big drop in intake temps, run after run, everything down-stream of the nozzle right up to the head wasn't just ambient temperature but physically COLD to touch.
-Big drop in coolant temps (and assume exhaust temps) car ran in the 85-90 degree mark and would warm slightly after each run, with the WMI turned on, the temp dropped back down to the 80 degree mark and held there.
-Boost holds better in the top end
-Mid range power and torque are both improved, peak power and torque are a touch higher.
How does the kit work? Well, after a bit of research I wanted to try WMI, but didn't like the 4 figure price tag of the Aquamist system, yet could see flaws in the on/off systems.
I ended up buying a cooling mist "stage one" on/off system, and experimented by modifying it my own way.
In brief, the hobbs switch activates a mechanical relay, that then sends power to a solid state relay, this relay is run off an injector earth, so that once pre-set boost pressure is reached the pump runs at the same duty cycle as the injectors. Having two relays does mean an extra point of failure, but also means if the hobbs switch, mechanical relay or solid state relay fail in the closed postion, I don't end up with 4 litres of water in the engine.
It's far from perfect, and does run a tad too much in some spots and not enough in others, but for $330, ($300 kit, $15 relay and $15 for conduit and other stuff) the gains are definitely worth while, and it's a step up from an on-off system.
The down-side being there isn't a fail-safe if the kit fails, so the tune was kept conservative to keep the engine in-tact if something does go wrong. A smaller nozzle with higher pump pressure would have performed better but this still works well.
Thanks to scotty nm35 for discussion about the SSR operation. And a big thanks and +1 to Cat and Trent at Chequered Tuning, exceptional to deal with from the beginning and very pleased with the entire tune!
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
