mine surged on 1/4 tank Lol
so you're pretty lucky to not surge on E
Agreed - mine also starts to surge at around a quarter tank. Sard pump with all the stock mounting stuff. Jez needs to corner faster :devil:
The sudden loss of all power is a give away - no wideband required.
So after a long day of testing today, they problem is as follows.
The pump has a main inlet where the hose and sock are connected, then there are 2 little holes where the fuel comes out. A priming/flow method for the pump.
Once the fuel level gets to below the fuel pump (where the 2 holes are exposed to air) the fuel pump needs 5 or 6 seconds of priming from a constant 12 volts before it starts to flow. In a GTR with a 0.7 sec priming cycle added to fuel rail pressure and the time it takes large injectors to fire = a long time of cranking over.
Now this is only a problem in applications where the fuel pump does not sit at the bottom of the tank i.e 33 34 GTR's. 32GTR's have a different fuel pick up set up hence no problem.
So seeing as I was the first 33GTR in unigroup to try the 400lph I was the lucky customer to be the guinea pig :S. boo I say.
Any way the solution Bosch 044 in tank haha.
Maybe nismoid can put this in his "handy threads" sticky to make it known for anyone who wants to run a 400lph Walbro, NOT to do so if the fuel pump is mounted in any other way other than close to the bottom.
Cheers
The dutch
Surely if the priming time was the issue you could extend the prime time? Why not give it a constant 12v.
Well if youve already put the 044 then thats that I guess.
Wanna sell your 400LPH?
The priming time would have to be changed to 8sec. Now that can be avoided if I just go to a 044.
As I said, I was at Unigroup all of yesterday, and we were testing pumps left right and centre. Tested 3 walbro 400lph outside the tank, and tested a 044.
The 400l was fine when submerged but no good when exposed to air. Did I really want a priming cycle of 8sec or maybe even more every time? No.
So we rigged up a 044 and did a swap, my 400l for the Bosch.
In short, sorry mate don't have the pump.
Cheers
The dutch
so the whole pump needs to be submerged ie if i was to mount it on the bottom of the tank it should be right? any one know how these go in a stagea 260rs 1999?how do these wire up?
Edited by R33huntme
Dave posted saying he knows how to "fix it" and he does, last time I was at Enique I was shown why they don't work when not submerged and it is a quick simple thing to fix, shot Dave a pm and I sure he would be willing to explain it, he is a really nice guy if you don't make yourself come across as a f**k stick
Lol, thanks.
He actually took the liberty of pm'ing me. He did inform me to block off 1 of the two holes associated with the priming system. Now thats all good and well, but leave that pump for long enough unsubmerged and the fuel leaks out again.
Either way, we tested them, saw how they worked, blocked off holes, submerged it, left it out of fuel, we did everything bar taking the bloody thing apart.
Its a shame they have to be modified. But I dont mind the 044. Still quiter than my stock pump I had. haha.
yes, quick and easy fix. and they are on special at vpw for like 120 dollars..
hopfully they realise this fault and re-design the inlet acordingly. you cant just block them up either as it doesnt alow for the pump to self prime. if they are fully submerged the whole time there output goes up heaps with both the bleed holes blocked. :0
  • 3 months later...
Just installed 1 into r33 GTR. So far no issue's even on empty but testing to see.
Looking at how hight the pump sits in tank i would think it needs alot more than 1/4 tank to be submerged.
What is the mod that u speak of Dave?
My fuel light is on and it is still fine Jez
If they dont have the bleed holes then they will work.
Also remember that the car drove fine all the way to empty. But as soon as you shut it off and leave it for an hour (enough time for the fuel pump to bleed off) then the car would not start with approx 15l in the tank
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
