  • Replies 7.5k
Posted Images
I work for node >_<
do you have anything to do with games.internode and getting mirrors setup im currently uploading a 10min movie of Toca Race Driver 3 i thought would be fun to share with the community im gunna try get it mirror'ed on node and GA so its free bandwidth for most ppls as its a rather large download
Unfortunately no >_< I have nothing at all to do with games - completely separate, It just seems to be that I never ever have anything to do with them.
Otherwise I would help for sure.
I used to be a mad gamer, back in the cs 1.3 days - but now i havent played anything other than xbox or ps2 for 2-3 years.
mike, what were the plates on the GTS1? If you were driving towards town i think i know who's it is (and its genuine GTS1, just with a diff engine dropped in)
spotted tim (r31turbo) while i was at tyrepower blackwood too
sorry, just the way u typed that sentence.. sounded weird to me.
doesnt matter.
SPOTTED:
andz69
Busy2k
Heslo
Neesaan GTS
R32Abuser
TuffR32
Mike_
Sinista
Leeman
Madaz
Pauly33
DVS R34
Matty_Tonkin
LunaticR32
Enrico
Lorenz
RyanRB25
PKblade
Nightcrawler
GFXman & friends
Trick & friends
Sambo33
Hostile
DC_Gtst
Race_24
Blue32
These people tonight at the meet. make sure you show up at designated location.
doesnt matter.
SPOTTED:
andz69
Busy2k
Heslo
Neesaan GTS
R32Abuser
TuffR32
Mike_
Sinista
Leeman
Madaz
Pauly33
DVS R34
Matty_Tonkin
LunaticR32
Enrico
Lorenz
RyanRB25
PKblade
Nightcrawler
GFXman & friends
Trick & friends
Sambo33
Hostile
DC_Gtst
Race_24
Blue32
Ill be there but only at the start cant go on the run :P
yeah had this tool in some red 31 drop into my work hey, dunno what he was on about. :P
cool adz looking forward to seeing u there, look out for me ill be parked next to andy with 511 as last dgits on my plate.
Saw HCR-032 today on flinders heading past wyatt at around 3pm, any1 here? nice beast.
Edited by Pauly33GTS-t
nice! will have to look for u! lol i ll feel out of place, wont kno any one! haha
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
