We found the end of power at 23.5 psi. These are the last few pulls adding timing.
Precision 6766CEA ball bearing turbo. We are also working on a prototype exhaust housing " variable vane" to bring down the power band.
Edited by Weapon X
  • Replies 69
Posted Images
Ported head, 270 cams, Full Race with my waste gate setup on it I like heat away from the intake side, factory intake 1000cc Injector Dynamics , all the normal and a few tricks. I'm going to put another intake on and see what happens. And try some 110 cct.
Here's a vid for fun of a 2nd gear pull. Dyno tune was done in 4th funny how a tune changes in second.
= Edited by Weapon X
it would be hitting differet load points in 2nd on the dyno unless running a really slow ramp rate
Not a bad output for the boost and fuel.
Looks laggy though 23psi at 5750rpm and only revving to 8000rpm?
What is is that attached to the rear housing of the turbo?
Where you looking/working out boost?
Just going off 90mph where it looks like everything starts to happen... 90mph = 145kph = 5180rpm (300rwkw)
I can't exactly remember what speed 4th gear pulls, but that RPM doesn't seem right to me. That would make 4th gear top at 195KM/H at 7000RPM...
If you are sure that 145kph is 5180rpm then this graph is almost identical to my graph. Same response, same power.
Well not 100% sure, just using Paulr33's old RPM calculation.
Could well be wrong! :)
By those same number 142mph / 228kph / 8150rpm
Can't remember what 8000rpm is in 4th on my car off the top of my head :wacko:
Me either - cant remember exactly what it is.
Piggaz is good with gearing, enlighten sir paul :D
8000 RPM on our car is 235 IIRC.
Oh. I just had a search around and found a word document I have saved over the years.
145 kp/h isssss... 4850 RPM according to this.
3000 RPM = 85 HP
3500 RPM = 120 HP
4000 RPM = 160 HP
4500 RPM = 240 HP
5000 RPM = 415 ish HP
5500 RPM = 470 ish HP
6000 RPM = 545 HP
6500 RPM = 610 HP
7000 RPM = 660 HP
7500 RPM = 700 HP
7900 RPM or so = 733 HP
* Going off the brown line
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
