Anything that isn't an actul issue/bug - please post here. Things you might want changed/enhanced etc
Ensrue you include a decent amount of information so that we know what you are talking about.
1. Screen shots if applicable
2. Links to other forums/features you've seen that you like
Updated 12/04 @ 19:00
  • Dark Skin
  • "Back to Top" button for both mobile & full versions
  • Drop Down Forum navigation box. Previous versions have all had it.
  • "Posts per Page" option is now gone. Old Forum had upto 50 posts per page, handy for viewing longer/detailed threads
  • Default Forum text is now larger than previous. Perhaps drop it back one size by default?
  • Instant PM button missing from posts in threads. Under Member Tags/User Bars, there was an instant PM button. Reinstated would be good, makes life easier using For Sale
Thanks
Ash
Can we please get a way to increase the posts per page? Like the old layout had the option of 40 PPP?
Other than that, fkn top work as always guys. I am already seeing lots of cool stuff I like better than the last layout.
Yes, this, 1000 times this. I had it on 50 or so per page (whatever the highest before it was modded was), I can't stand having to change page constantly.
This is also what I came here to say
Can you please explain what you mean in greater detail, include screen dumps etc.
Overall size of font across the page is pretty large.
be good if there was custom function to say choose between 3-4 font sizing.
Screen shots
Cant really see in the screen shots but font sizing for me is like reading a book with large print.
Bar that it all looks good !!
who ever thought of the ''show new reply'' button when you're replying to a post is a genius.
but when you click ''show new reply'' then post what you were writing and then exit the topic, it doesn't realise that you read it and it says there's a new reply.
Also, is there a way for users to choose to turn off/on previews in the "reply" box please?
I find it a lot easier having text only in that box and being shown the image/video/media/URL/etc link tags
Thanks
Thanks
Can you post a screen dump, not entirely sure what you mean.
Just noticed the drop down menu for moving from section to section which used to be between the quick reply box and the last post on the right hand side is missing
Already on the list!
It's all gone pear shaped.
Using Firefox.
At the top of the topic, I'm getting the window tabs being reporoduced, rather than the thread topic.
In the SAU banner, I'm getting something else overlaying / interfering with the menu options.
I tried doing a cut & paste to eshow what I mean, but it doesn't seem to want to work correctly (work the way I want it too).
It's all crappy, AFIC.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
