I dont know how I forgot to post this. It's my surge tank and AFM delete pipes. I painted the surge tank black so headlights didnt reflect off the alloy..... because im a nice bloke ;)
Bobby, the box is a OS 1-3 gearset with the big dick input shaft. It was behind the engine before. It got pulled down and put back together since. Nice box but really needs a stroker to work.... Orrrr have smaller turbos!
I can't see myself revving any harder than 8000 RPM. I found myself with the -5's changing at 6500 and just ride the torque. See where the power drops off but 8000 RPM will be the shift point with the hard cut set at 8600-8800 JUST so I don't hit it.
Nice
Since your not reving past 9000 rpm its all good, and you will notice it set up like this it will want to rev and the squish will make these turbo's come on boost at a lower rpm. I guess you will be able to compare to your last build with the dyno sheets.
Cant wait to see the results.
Nice
Thats why I decided to run the -5's again. The whole time I was building the head it was "response, response, response". I have been assured it will crack 450 but im more interested in the mid range.... The goal is 400 by 5000 RPM.... I wasn't that far off it before it died.
With the single, time will tell!
A tad bummed I took the valve relief out as I qould have been around 9:4 - 9.5:1 but atleast it's not 8.5!
Bring on the tune!
Pooooorrnnn
Who made that for you of you don't mind me asking??
I took it to Unigroup and said "Give me a 5 litre surge tank under the car... GO".... I got that back.
I've never had an issue... I have a Fuel pressure gauge in the car.
i'll evenutally put a little fuel cooler like what Bobby did. i've seen the data that Unigroup has of warm/hot fuel and its just downright scary!
Sweet yea I've been looking at similar options but want it under car, fuel cooler for sure
Nice to see your build nearly finished can't wait to see the end results both twin and single
Single will make more grunt for sure.... the question is if it can match the twins mid range and driveability!
Please don't take this the wrong way but I can't believe it's taken 22 pages to get to this point!
Should be a weapon once it's done. Looks sexy too! Can't wait to see some videos.
I'm at the crossroads of doing a dirty 30 or stroking the 26 so your results may make a difference.
Good luck once you hit the dyno!
Just waiting on parts and people, not to mention the shit talk in the thread.
Starting fresh? 30 hands down!
I'm doing the 2630 conversion into a GTR and if I started again it would be the BC 2.9 kit
Paul, would love to see this on the dyno, I'm free Thursday should be done by then yeah :P keep the pics coming, love your work it gives me ideas
Where are you upto with it man?
Ideas? What ideas are you talking about?
good, just waiting another fitting for the oil pump to external feed it which is going to work better then I thought with heaps of clearance from the AC, then 3 bungs into sump for the oil cooler setup and I came close the bottom end then it's just the hot side gaskets and lines Quaife diff and Ross balancer then insert it in car
when I say ideas I mean copy you of coarse, things like the pipes into turbos, though I melted one of then, the surge tank, possible cams etc
sorry if that's not clear to read I changed the turbo on my truck today and gave it a service and thought I could use a beer or 11 so far after doing so
what about a 30 with a nitto 3.2 stroker....just sayin.
Awesome looking surge tank Paul
I'm actually thinking about doing this next year, still trying to to decide if I can justify the cash or not
I've been there and built an rb2630...fun it was but it simply didn't feel like a gtr anymore (damn block is out of a vl commodore) and it really annoyed me that things didn't line up the way it should have by having to extend inter cooler pipes etc blah blah.
My mate bought a my12 r35gtr...now that is shockingly quick and its stock!!! My old gtr would have still got it though :)
The engineering and tractable power is really mind blowing.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
