OS twins are scrub too.
The larger input shaft is nice but isn't that necessary. I had to upgrade my clutch hub which was available for my Carbonetic twin clutch. Fits good.
I don't think they can mix much but PPG 1-3 dog and 4-5 synchro (or was it 1-4 dog) was a kit I thought and is ok on the street. Big power most times need big gearbox sadly.
Yeah, that's what the guy I'm talking to said he could do. 1-4 dog straight and 5th helical synchro.
I need to drive one to get some sort of idea of what these dog boxes are about.
Just throw a rb20 box behind it and forget using ya front wheels, guaranteed to hold as much HP ya can throw at it :P
lol but on a serious note go the PPG 1st-4th dog and 5th helical synchro. There's honestly nothing to them. You dont have to drive them hard or abusive as so many people say, it does them no harm driving the PPG dogs softly. Ive driven one personally in a mates old r33 26/30 GTR. Was intially a little strange and kinda didnt like it but as the day went on and I got use to it, it grew on me. Although I will admitt im unsure of servicing costs. He had it 2yrs/20,000 odd km's with no hickups supporting around the 500kw mark in that time. This is probably useless info to you paul but thought id voice my opinion haha.
Now back to the BEERS! :)
http://www.rhdjapan.com/os-giken-close-gear-kit-5-speed-nissan-rb26dett-input-shaft.html
2800 Paul, not sure what you're looking for but that's a pretty decent price.
I think I am going to do if it stays like that a little while!
$2800 Paul, not sure what you're looking for but that's a pretty decent price.
he just broke one of them
As Brett said. Also, good luck getting one. A fellow member has had one on order since June I think. Delay, delay, delay.
I just got a lengthy email back from PPG. Gonna call him on Monday and organise to fly down to Adelaide and drive the different boxes. He said that the helical, synchro set will do the job but really is pushing the dog set. He owns a GTR with that box in it. Been in the car for 6 years/40,000 kms and its all sweet.
Interested to hear how it goes. I'm looking at the 6 speed PPG dog set at the moment to replace the standard getrag gear - waiting on pricing back and how customisable the ratios are.
Like you have never driven a dog box but street manners less important for me - it's already a pig on the street!
From what I can gather, I don't think they like to budge on the ratios they have on offer.
Ill sit down and work out the difference between standard 34 ratios and the PPG ratios, then throw in what they are on 4.11's.
I have one of the early 1-4 helical PPG gearsets... Good thing and once you learn to drive a non syncro box it's a lot more rewarding to drive. Plus if my missus can drive it successfully, anyone can.
OS triple is the worlds most brutal and hardest clutch to drive. I had one and was absolute rubbish.
... ba ha ha ha ha ha. Once you set the pedal height properly, it's not really that bad. I've driven much worse.
... again, if my missus can drive it in traffic... you must be doing something wrong.
Just a note on input shafts.. I opted to leave my input shaft stock. I look at it as a fusible link, as my clutch is unlikely to slip too much... so the stock shaft provides some protection to my gear set if serious shock loading occurs.
Cheers
Justin
  • Like 2
Cheers
Justin
i wish to like your post more than once
Cheers
Justin
So you reckon the dogs ain't that bad?
I've spoken to PPG the other day, damn long phone call. He is getting back to me with pricing on the straight cut synchro IF they're willing to do it.
The guy I'm dealing with has the helical dog set in his own GTR and loves it. Just need to drive one to see what the go is.
Cheers
Justin
Is your missus a race car driver?? :P
  • Like 1
at least put a 6 litre in it :P
Pfft, 6 ltr, that's to small, 9.4 litres is where its at.
> http://www.proformanceunlimited.com/specs/572_750.html
And for well under 25k dropped at your door.
Don't swear at me, Mark :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
