If your willing to take the hub apart then i still think it should be pretty easily do able on a cnc machine.. let me know if you get stuck finding someone to machine it.
I have a few mates with access to 5 axis cnc machines who should be able to do it.
I'll keep that in mind mate, cheers.
I'll see how I go tomorrow.
Try this mob too Paul..they would be able to machine and cut the internal splines no problem. As for cost to do it i couldn't tell you.
http://www.manufacturelink.com.au/Suppliers/command-engineering.aspx
Also depending on the size step up in diameter you might be able to machine the existing hub out and just re spline it if there is enough meat left to do it.
Edited by ezy_09s
That sucks about the clutch plates. With our NPC twin plate in the race car when we switched to the PPG gear set which was using the Chevy splined input, they just took out the Nissan centre splines and riveted in a Chevy spline boss to both plates.
I don't know whether you have driven a car with a NPC twin plate before but its a solid type clutch which I would swear is just as light as a standard clutch and drives likes a standard one in terms of take up when released. Its crazy how nice it is for a 1000hp rated clutch.
Its an option you could look at if you cant find a solution for your current clutch.
I'll ring that St Mary's mob tomorrow.
Any idea who I should be speaking to?
Edit: John apparently :D
Scott, talk to scott, he is Johns son and more into the import/performance side of things
Not saying John doesn't know his shit cause he does I've just always dealt with scott when it comes to the cars and John with the truck and 4wd stuff
Can't say I have driven a car with an NPC. Not sure if the Nismo twin is built the same way as the NPC but apparently it's not that easy. (What Jim Berry told me)
Any chance you could just get the plates from a exedy chev clutch and drop em in, providing their the same diameter the rest should be the same given the twin plates aren't factory replacement but a full replacement
Talk the Scott, he'll know
What about PPG themselves, its their box and shaft, surely they wouldn't sell it with this setup if you couldn't get a clutch for it
That could be an idea.
It's not the clutch that's the problem, I just want the big spline in a coppermix. Nismo don't have that option.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
