If your willing to take the hub apart then i still think it should be pretty easily do able on a cnc machine.. let me know if you get stuck finding someone to machine it.
I have a few mates with access to 5 axis cnc machines who should be able to do it.
I'll keep that in mind mate, cheers.
I'll see how I go tomorrow.
Try this mob too Paul..they would be able to machine and cut the internal splines no problem. As for cost to do it i couldn't tell you.
http://www.manufacturelink.com.au/Suppliers/command-engineering.aspx
Also depending on the size step up in diameter you might be able to machine the existing hub out and just re spline it if there is enough meat left to do it.
Edited by ezy_09s
That sucks about the clutch plates. With our NPC twin plate in the race car when we switched to the PPG gear set which was using the Chevy splined input, they just took out the Nissan centre splines and riveted in a Chevy spline boss to both plates.
I don't know whether you have driven a car with a NPC twin plate before but its a solid type clutch which I would swear is just as light as a standard clutch and drives likes a standard one in terms of take up when released. Its crazy how nice it is for a 1000hp rated clutch.
Its an option you could look at if you cant find a solution for your current clutch.
I'll ring that St Mary's mob tomorrow.
Any idea who I should be speaking to?
Edit: John apparently :D
Scott, talk to scott, he is Johns son and more into the import/performance side of things
Not saying John doesn't know his shit cause he does I've just always dealt with scott when it comes to the cars and John with the truck and 4wd stuff
Can't say I have driven a car with an NPC. Not sure if the Nismo twin is built the same way as the NPC but apparently it's not that easy. (What Jim Berry told me)
Any chance you could just get the plates from a exedy chev clutch and drop em in, providing their the same diameter the rest should be the same given the twin plates aren't factory replacement but a full replacement
Talk the Scott, he'll know
What about PPG themselves, its their box and shaft, surely they wouldn't sell it with this setup if you couldn't get a clutch for it
That could be an idea.
It's not the clutch that's the problem, I just want the big spline in a coppermix. Nismo don't have that option.
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
