If your willing to take the hub apart then i still think it should be pretty easily do able on a cnc machine.. let me know if you get stuck finding someone to machine it.
I have a few mates with access to 5 axis cnc machines who should be able to do it.
I'll keep that in mind mate, cheers.
I'll see how I go tomorrow.
Try this mob too Paul..they would be able to machine and cut the internal splines no problem. As for cost to do it i couldn't tell you.
http://www.manufacturelink.com.au/Suppliers/command-engineering.aspx
Also depending on the size step up in diameter you might be able to machine the existing hub out and just re spline it if there is enough meat left to do it.
Edited by ezy_09s
That sucks about the clutch plates. With our NPC twin plate in the race car when we switched to the PPG gear set which was using the Chevy splined input, they just took out the Nissan centre splines and riveted in a Chevy spline boss to both plates.
I don't know whether you have driven a car with a NPC twin plate before but its a solid type clutch which I would swear is just as light as a standard clutch and drives likes a standard one in terms of take up when released. Its crazy how nice it is for a 1000hp rated clutch.
Its an option you could look at if you cant find a solution for your current clutch.
I'll ring that St Mary's mob tomorrow.
Any idea who I should be speaking to?
Edit: John apparently :D
Scott, talk to scott, he is Johns son and more into the import/performance side of things
Not saying John doesn't know his shit cause he does I've just always dealt with scott when it comes to the cars and John with the truck and 4wd stuff
Can't say I have driven a car with an NPC. Not sure if the Nismo twin is built the same way as the NPC but apparently it's not that easy. (What Jim Berry told me)
Any chance you could just get the plates from a exedy chev clutch and drop em in, providing their the same diameter the rest should be the same given the twin plates aren't factory replacement but a full replacement
Talk the Scott, he'll know
What about PPG themselves, its their box and shaft, surely they wouldn't sell it with this setup if you couldn't get a clutch for it
That could be an idea.
It's not the clutch that's the problem, I just want the big spline in a coppermix. Nismo don't have that option.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
