Hey Paul, as discussed - I used to run 044 in tank, changed to Walbro 460 for e85. Nearly kept up with demand but was on the edge and needed surge tank for track. I considered a number of "big single" fuel pumps - but most American gear I looked at had "duty constraints". ie not to be run at full duty for more than X minutes..
also, mixed results on 'noise' depending on who you talk to. Have sat in a few cars with Aeromotive, Maganflow etc that all you could hear is fuel pump.
this is ok if its a track car only - but to me, even a track car with a quiet pump means you can hear 'other stuff' that you want to hear.. so if you can get performance AND have a quiet pump - then why wouldn't you. Considered speed controlling these and even bought a Fuelab to do just this but did not go ahead based on other factors.
I think there is something to be said for OEM manufacturers. Generally cheaper (replaceable easily), reliable, often quieter, less amps draw (sometimes).
Running e85, I wanted no 'corrosion' so surge tank had to be completely anodised throughout. There is anodising and there is anodising. You want Type 3 Hard anodising done if you get it done locally - this stands up best but it is not 'by default' what you get - you must ask for it.
All lines are Speedflow Series 200 Teflon lined. No corrosion and no smell.
I ended up running a radium surge tank which is well made, properly anodised throughout and holds 2x Walbro 460 e85 pumps. Could have fabbed our own but why reinvent the wheel when this was a good solution. I only switch the second pump on under high load, so it sees very little duty (so it should out last the main one). With e85, there is much less chance of engine damage if you lean it out... and remember a big single pump can still 'slow down' over its life, so the argument there is.... arguable. At least when #2 pump fails you know about it. A big single slowing could catch you out over time.
regarding lift pumps, people have mentioned you can use another Walbro 460 for that - BUT, check out their current draw. They draw big amps even with no load or pressure.. about 10A from memory. If you are at full noise with all three pumps going at 20A + 20A +10A you can be drawing 50A for fuel pumps! (admittedly only at certain times)... with all the other gear we're running and CDI/fans etc... you want to keep it down where you can
I use an e85 rate Pierburg Lift Pump which only draws about 2A and easily keeps the surge topped up.
End result is I have a fuel system that you cannot hear even if you put your ear to it. It is capable of well more than my cars puts down in HP.
Parts are easy to get locally for replacement. All pumps are submersed in fuel - which I also believe keeps them happier in terms of temp and environment. ......and the surge tank is pretty to look at. Bonus. :)
  • Like 4
Sure - its one of the most bling things on my car actually. Normally its all about function and lightweight, but went a bit overboard with a CNC aluminium "shelf" to fit a lithium battery, the relays (hidden behind battery when installed), surge tank and holders for the canisters from the AST Suspension.
The surge tank can take up to 3x Walbro 460 e85.. I run just the two. Pierburg 2A Lift pump in tank.
  • Like 8
Hater! :)
I have a Mangafuel Protuner 625 that doesn't need PWM and doesn't have runtime restrictions (I have done hundreds of KM's then done 1000m drag runs without issue) but it's a noisy f**ker. I'm constantly considering the same option as our male model friend here, twin Walbro 460 pumps. I had one in my last green car when they first came out, fantastic pumps and almost silent.
Edited by SimonR32
That setup is mint, Matty.
As I said on the phone today, i've bought one of those Holley dominator 1800 pumps. By all accounts it should satisfy everything that gets thrown at it.
Bit of an update.
I finally got the car home. Huge issues with injector baskets filling up with this super fine silt. Its small enough to get through the 23 micron filters I have post pumps. The baskets have been cleaned about 6 times, fuel filters twice. The intank pump was flogged so a Walbro 460 went in as a lift pump. Definitely a whole fuel system clean out is in order. I have a few large 6 micron fuel filters coming also.
The modified transfer case has settled the car down alot too. With the GT Pro in the rear set to medium, it was very taily. It feels much more planted, can get on the loud pedal earlier. Win win!
The tune has been relaxed also. Boost controller is turned off, 3 degrees of timing taken out and 6-7% more fuel across the entire map just to make it super safe with this fuel problem. It still went onto make 415rwkw. Did a comp test and its 190 psi across all 6 pots.
The box is great. Definately "woke" it up. The clutch is better than expected also.
28268977-DC49-4393-B984-34533CC3DFAB_zps
What the intank sock looked like.
7A4194A9-20D1-4329-9304-B668EE32112A_zps
Bit of box porn.
  • Like 3
Dang. You make me think dumping this old wore-out box on the curb and getting a fresher, younger, but more expensive box that may let me thrash it more before complaining.
Wait...we aren't talking about wives?
  • Like 2
http://vid1068.photobucket.com/albums/u457/Ptriffitt/F690A0AE-CCD6-4CEF-A3DD-3D47EE493AFF_zps0mlky3ck.mp4
For shits and giggles I took a video of the warm idle just before the compression test. On E85 you would hardly know it has cams in it.
http://vid1068.photobucket.com/albums/u457/Ptriffitt/D2CDE898-D824-4475-8145-56E87DFD29A6_zpsu2e9b2mn.mp4
A bit of box action. 415 KW, 19 PSI, super relaxed tune.
  • Like 4
Well what can I say, your passenger said it all. :special:
Love that box , box Mmmmmmmmmmmm
  • Like 2
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
