Hey Paul, as discussed - I used to run 044 in tank, changed to Walbro 460 for e85. Nearly kept up with demand but was on the edge and needed surge tank for track. I considered a number of "big single" fuel pumps - but most American gear I looked at had "duty constraints". ie not to be run at full duty for more than X minutes..
also, mixed results on 'noise' depending on who you talk to. Have sat in a few cars with Aeromotive, Maganflow etc that all you could hear is fuel pump.
this is ok if its a track car only - but to me, even a track car with a quiet pump means you can hear 'other stuff' that you want to hear.. so if you can get performance AND have a quiet pump - then why wouldn't you. Considered speed controlling these and even bought a Fuelab to do just this but did not go ahead based on other factors.
I think there is something to be said for OEM manufacturers. Generally cheaper (replaceable easily), reliable, often quieter, less amps draw (sometimes).
Running e85, I wanted no 'corrosion' so surge tank had to be completely anodised throughout. There is anodising and there is anodising. You want Type 3 Hard anodising done if you get it done locally - this stands up best but it is not 'by default' what you get - you must ask for it.
All lines are Speedflow Series 200 Teflon lined. No corrosion and no smell.
I ended up running a radium surge tank which is well made, properly anodised throughout and holds 2x Walbro 460 e85 pumps. Could have fabbed our own but why reinvent the wheel when this was a good solution. I only switch the second pump on under high load, so it sees very little duty (so it should out last the main one). With e85, there is much less chance of engine damage if you lean it out... and remember a big single pump can still 'slow down' over its life, so the argument there is.... arguable. At least when #2 pump fails you know about it. A big single slowing could catch you out over time.
regarding lift pumps, people have mentioned you can use another Walbro 460 for that - BUT, check out their current draw. They draw big amps even with no load or pressure.. about 10A from memory. If you are at full noise with all three pumps going at 20A + 20A +10A you can be drawing 50A for fuel pumps! (admittedly only at certain times)... with all the other gear we're running and CDI/fans etc... you want to keep it down where you can
I use an e85 rate Pierburg Lift Pump which only draws about 2A and easily keeps the surge topped up.
End result is I have a fuel system that you cannot hear even if you put your ear to it. It is capable of well more than my cars puts down in HP.
Parts are easy to get locally for replacement. All pumps are submersed in fuel - which I also believe keeps them happier in terms of temp and environment. ......and the surge tank is pretty to look at. Bonus. :)
  • Like 4
Sure - its one of the most bling things on my car actually. Normally its all about function and lightweight, but went a bit overboard with a CNC aluminium "shelf" to fit a lithium battery, the relays (hidden behind battery when installed), surge tank and holders for the canisters from the AST Suspension.
The surge tank can take up to 3x Walbro 460 e85.. I run just the two. Pierburg 2A Lift pump in tank.
  • Like 8
Hater! :)
I have a Mangafuel Protuner 625 that doesn't need PWM and doesn't have runtime restrictions (I have done hundreds of KM's then done 1000m drag runs without issue) but it's a noisy f**ker. I'm constantly considering the same option as our male model friend here, twin Walbro 460 pumps. I had one in my last green car when they first came out, fantastic pumps and almost silent.
Edited by SimonR32
That setup is mint, Matty.
As I said on the phone today, i've bought one of those Holley dominator 1800 pumps. By all accounts it should satisfy everything that gets thrown at it.
Bit of an update.
I finally got the car home. Huge issues with injector baskets filling up with this super fine silt. Its small enough to get through the 23 micron filters I have post pumps. The baskets have been cleaned about 6 times, fuel filters twice. The intank pump was flogged so a Walbro 460 went in as a lift pump. Definitely a whole fuel system clean out is in order. I have a few large 6 micron fuel filters coming also.
The modified transfer case has settled the car down alot too. With the GT Pro in the rear set to medium, it was very taily. It feels much more planted, can get on the loud pedal earlier. Win win!
The tune has been relaxed also. Boost controller is turned off, 3 degrees of timing taken out and 6-7% more fuel across the entire map just to make it super safe with this fuel problem. It still went onto make 415rwkw. Did a comp test and its 190 psi across all 6 pots.
The box is great. Definately "woke" it up. The clutch is better than expected also.
28268977-DC49-4393-B984-34533CC3DFAB_zps
What the intank sock looked like.
7A4194A9-20D1-4329-9304-B668EE32112A_zps
Bit of box porn.
  • Like 3
Dang. You make me think dumping this old wore-out box on the curb and getting a fresher, younger, but more expensive box that may let me thrash it more before complaining.
Wait...we aren't talking about wives?
  • Like 2
http://vid1068.photobucket.com/albums/u457/Ptriffitt/F690A0AE-CCD6-4CEF-A3DD-3D47EE493AFF_zps0mlky3ck.mp4
For shits and giggles I took a video of the warm idle just before the compression test. On E85 you would hardly know it has cams in it.
http://vid1068.photobucket.com/albums/u457/Ptriffitt/D2CDE898-D824-4475-8145-56E87DFD29A6_zpsu2e9b2mn.mp4
A bit of box action. 415 KW, 19 PSI, super relaxed tune.
  • Like 4
Well what can I say, your passenger said it all. :special:
Love that box , box Mmmmmmmmmmmm
  • Like 2
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
