3 hours ago, Leroy Peterson said:
Tomei sponsored, so parts would cost zero. If you had a stock R and tomei gave you all those bits for free, would you install them?
The cam gears yes, the rest no
No. Only the cam gears. Rest would be in a for sale thread on SAU.
Nope I would prefer the standard setup would drive much better
So if Tomei offered you a heap of free shit you would say "no I'd prefer to drive my stock (slow-ass) GTR"?
Yeah, sure you would...
Have you seen the dyno graphs floating around for these Tomei turds? They're absolute garbage. I'd rather spend money out of my own pocket than run free snails which are garbage.
  • Like 1
look at the video on the previous page.
tuned stock turbos would be more fun
28 minutes ago, Nismo 3.2ish said:
YET, lol
Did you get a chance for a ride/drive in one of his great Rs
Nah.
the world record car was on a hoist. There was a 32 without an engine and box in it. Heaps of finished engines all wrapped up.
5 hours ago, Piggaz said:
Nah.
Bad timing :(
Did you get to talk to Rob about what you are doing with the Whale ?
When are you back ?
26 minutes ago, Nismo 3.2ish said:
Bad timing :(
When are you back ?
Didn't really mention my car at all.
Im back on Tuesday.
